HAMMERHEAD
Truck sometimes starts right up and idles fine.Sometimes the idle does not want to come down below 1000. Yesterday, I let it run for a while and the idle finally dropped down to around 850 or so and was smooth but if you tried to give it any gas, it would not take any at all. If you tried to give it any at all, it would pop in the intake and would shut off.
I have replaced the ignition module and the iac but did not make any difference. Then yesterday while it was running in the weird mode (smooth but would not take any gas) I tried changing the settings on my ultimate chip. I could scroll to the security mode while it was running and it would not shut my truck off.
Later, after running for a while, it would switch back to idling ok and I could rev the engine and everything was ok and the security setting on the chip would cut the truck off. I'm stumped. Today, I am going to pull the ecm and check the plugs and see if the chips are plugged in all the way. Maybe over the years the chips have worked their way out a little from all the rough roads. I doubt that is the case but gonna check anyways. Maybe my ecm took a dump.
I do not have any test equipment. I have data master on my laptop but no cable and no knowledge on how to even use it. Car shows and nice weather is on the way and I am desperate to get her back on the road again. Any help or advice would be appreciated. I would even pay someone with the knowledge to help me diagnose before I put her on a trailer and make an appointment with Sportmachines.
