Will a defective intercooler throw a code? ---
alwayscode390
pppssssshhhhhtttttttttttt
I was getting a tuneup today and the mechanic told me he "doesnt think" my intercooler is working. I am throwing NO codes right now. I dont think my SY was hot enough to get the intercooler going, isnt it 215 degrees before it turns on? Thanks for the help ---
Daron
Re: Will a defective intercooler throw a code? ---
Get that pump working all the time.
alwayscode390
I just drove the truck 1100 miles in 2 days and never got to 215 degrees.....is that when the cooler kicks on? Also , here is the diagnosis from the mechanic ( cheap place ) " When attempting to BLEED intercooler, it was discovered that the intercooler pump was inoperable " . Does that even sound right? BLEEDING sounds more like an AIR pressure type of thing isnt it??? Thanks guys :) ---
jwaller
Evil Genius/SyTy Guru
it is normal to burmp the air out of the IC system an yes the IC pump does not come on in the stock chip till 184degF. hot wire it or get a better chip that will turn it on sooner.
alwayscode390
I will chip my truck....then if I dont hear it come on ( its easy to hear RIGHT? ) .... I will have to replace it. Whats the best replacement intercooler if I have to go that route? ( I just got the truck 2 days ago, sorry if I seem like a noob , lol ) ---
jwaller
asking what the best IC is, is like asking whats your favorite color. too many to list and most of it depends on what you want out of your truck. mostly stock motor and DD use. then upgrade what you have with a larger pump and replace the metal lines with hoses. maybe a larger upper/lower if you get the $.
try looking here for more info.
http://www.sportmachines.com/maintenance/aux_ic.php
this will also answer all your nOOb questions you might have.
http://www.sportmachines.com/maintenance/beginner.php
alwayscode390
Lets say my intercooler is bad, all I have to do is replace to an UPGRADED pump anyway right?! The assembly is still fine isnt it? THANKS GUYS ---
jwaller
by saying your intercooler is bad that would usually mean a something other than the pump. if your pump is bad then so be it and replace the thing.
sy538
http://www.autoperformanceengineering.com/ sells IC pumps for sytys.
Before you buy one, hot wire the pump and check to see if it's getting power. If its not, check the fuse behind the alternator, if that is good, get the relay from GM - take the part #.
alwayscode390
Thanks guys .... I am clueless about this, hahaha. I will try to hotwire it , but I still dont know how to tell if my intercooler is bad or just my pump or both , lol. I will catch on soon enough ;) ---
sy538
alwayscode390 said:
...if my intercooler is bad or just my pump or both ...
The pump is the only thing that can really go bad. Our IC system is basically 2 radiators, an electric water pump and hose. You could have a dead pump, a good pump that is not getting power, a kink in you hose, no water, or a leak in the system. Those are the only problems I can think of. You can’t really troubleshoot it if it is not hotwired because you won’t know if the pump is running (with the engine running you can’t hear it) or even if it should be. When hotwired, it will run with key in the “on” position even when the truck is not running. So, hotwire it, turn the key to on without starting the engine, go to the front of the truck and if you can’t hear it then it is not running. Use a test light to see if it is getting power. If not, check the fuse, if it is good replace the relay on the firewall (take the part # off of the top of it because the dealer will not now what you are talking about) it costs about $10. If the pump is getting power but doesn’t run, get a new pump from APE. If you have to replace the pump, replace the lines with heater hose, a little clear hose will help with getting the air out.
If I had it to do again I would make sure the pump is pulling water out of the bottom port in the upper IC and pushing into the cche. Mine is pulling from the cche and pushing into the upper IC, making it extremely difficult to get the air out because you can not remove the cap while the pump is running or water will run out like a freaking water hose. I never got to see what a stock pump flows like, as mine was dead when I bought the truck, but the APE pumps work very well.
alwayscode390
sy538 that was a GREAT answer, thanks ALOT, I am ready to tackle this now :) ---
