will not start
PJ2397SY
just reassembled after intake gaskets and just turns over.
check guages light flashing
check eng lite on
45psi in fuel rail
spark off of coil
any sugg?
BigBadSmoosh
Re: will not start
its just cranking?
did you hook up the fuel rails right? is the injector harness connected?
any spark at the plugs?
tealty
Re: will not start
Did you only rip off the upper and lower? I'd check to see if plugs are wet, which will mean the injectors are opening. Then check timing....prolly off 180*? Pull the code by jumpering a and b terminal on the aldl with a paperclip.
yeah with the check engine light, this now has me thinking its electrical (duh). I'd check all electrical connections that you played with. Injector connectors, dist, and main connector that connects the inj harness to the main harness.
later
Jordan
PJ2397SY
Re: will not start
Injector harness was disconnecting
Reconnected harness
Engine turns over now then abruptly stops. Engine cranks over 10 times then stops
Code 12 is flashing
PJ2397SY
Re: will not start
ecm fuses are ok
plug wires are correct
truck is now turning over but not steady
kinda like hiccuping
dist is in and my marks line up and rotor lined up w/marks i made prior to removal
bezerk
Re: will not start
PJ2397SY said:
ecm fuses are ok
there are 2 timing marks on the stock balancer..
take off the cap, let the rotor point to #1 cil..
you could be 180 of, than change the wires 180* and try again..
