Re: WTB: Boost Solenoid w/Harness
I am looking for a good boost solenoid for my Syclone and the harness that plugs into it. I only need enough harness wire attached to allow me to splice into the existing wire on the truck. My harness has bare wires right at the plug so it can not be spliced. I also need the bolt that attaches the solenoid to the turbo. Mine has disappeared.
Hopefully someone has this stuff lying around. If you do, please shoot me a PM with price shipped to 58727.
Thanks in advance.
The bolt is an ordinary bolt that you can find in the metric section of a hardware store.
The connector can be generally had through most parts stores as a repair pigtail. You can also find them in a junkyard on mid-90s gm diesel trucks (and probably lots of other applications, the connector is common)
The pins will come out of that connector with a pick, if you want to fix it that way.
You can "poor man's test" that solenoid with an air compressor and a 12V battery source. Apply pressure to the "in" side with no wires hooked up... air should only come out of one side.
With 12V applied across the pins, apply pressure again... air should only come out of the other side.
Test works a lot better if you use a MityVac pump as the air source, as you can control it better.
