Slyclone
Well-known member
I am currently looking for 1 good PCV from TB to the valve cover. This includes the hose, PCV fitting, and possibly the T. If some one has a whole assembly avail. I may take the whole part.
What I am seeing is a nasty oil drip in that area. Small puddle of oil is gathering under the TB fitting in the lower manifold casting. It appears the hoses may be hard and brittle due to the heat up there and have gone bad.
I am also looking for 1 power cable. Those who talk about the purple wire dilemma or remedy. I pulled my starter and it looks as if my cable for the power is clearly worn through to where it worn the casing off and already started to patina. From what I see I am lucky I did not have a fire.
If anyone has a cross reference or part number GM for the cable- Or some one has one laying around. Thanks
