Need the front slip yoke for a stock Sy driveshaft - mine got dropped and dinged up the surface pretty bad.
Let me know what you have.
Want new or used?
I might have one? I will have to double check tomorrow...
Dig: A heads-up. Most 4L60 and 60e 1st gen 2WD blazers, jimmys, Astro Safari etc use the 27 spline output yoke. Also most 2-piece rear driveshaft S/T pick-up (even a 4X4) also use the 27 spline. Prior to 92 I don't think there were any 32 spline output shafts in S/T series. And from 92-on the 32 is in single piece driveshaft 4X4 only. Most still have the 27. The 27 is very common. The 32 is not.
Might help you if you resort to junk yarding.
Regards,
DaveP
Am I missing something ( buy a new one )
Ray
Dig, If you don't come up with one soon. Let me know. I should be able to get one from the pull-a-part around here.
Dig, did you try Luckens in Winger Mn? They even use to have a Syclone there a few years back.
