Zeitronix data logging dilemma
djwaggoner
I have been chasing this problem for over 2 weeks w/o a solution. I have installed the Zeitronix WB & data logger on my Ty, and the AFR, EGT, BOOST all work correctly on the ZT2 display and also on the logging graph (& dashboard).
The tach signal however, is a high frequency square wave that doesn't change frequency w/ RPM, but it _does_ move up & down w/ RPM....same square wave just higher on the graph.
I've searched here several evenings for any similar problems and found _some_ ideas. I've been communicating w/ Mark @ Zeitronix & he's had several suggestions.
So far, I've tried picking up the tach signal from both wires from the dist to coil, the tach wire from the coil to the IP, and the dist ref signal to the ECM - all I've gotten is a change in magnitude of the same graph.
I've tried moving the 12V power source to the distribution block on the firewall, and to the batt directly.
I've moved the ground to a separate site (accel pedal mount), to the fender, to the frame and direct to the batt no help.
I've checked the resistance of the dist pickup coil, the continuity of the dist-coil harness, replaced the ign module in the dist, have fresh plugs, wires, and cleaned the rotor & dist cap contacts (have only about 500 miles on them).
I even changed out the alternator in case it was a noise source........
I've downloaded and installed the latest software V3.0.3 and while I've been working on it - the newest V3.0.4 which superceded it.
Still seeing the same graph....
Has anyone else seen this?
Does anyone have a fresh idea for a solution?
Thanks,
David
Windedv6
Ty n 10s
Re: Zeitronix data logging dilemma
I doubt if anyone on the board is using the Zeitronix WB & data logger. I use their E85 analyzer and it works nicely, but have not used any of their other products. They seem to be a good company support wise.
John
turbodig
Well, my question would be- what does the zeit unit expect for a tach signal? A dissy style tach signal or ?
I run a LMA-3 Innovate box on the buick, similar creature.
djwaggoner
The instructions say to tap the tach signal at the coil......so it _must_ be able to convert a pulsatile signal.
The factory tach works normally - same wire........
