help, no reverse and...
msheller
help, no reverse and it revs way over red line in each fwd gear...everthing was fine and then I went to pull out hard once(med to med/hvy throttle) and it revved way hi and then clunked into 2nd.....what do you think is up?
Thanx,
Matt
Captain Morgan
Moderated User
Re: help, no reverse and...
broken input or output shaft?
does it actually move in forward when you redline it? (also not a smart thing to do)
could be a torque converter issue or a number of hard parts.
either way you broke something, take it out and prepare to shell out some bucks.
msheller
it drives almost normally in D...just revs hi....and no reverse....precision ind vigilante 2800 is the converter...
Captain Morgan
Moderated User
could be a flipped sprag?? Im not sure if loss of reverse is a result of that or not.... i cant rememeber, ive broken mine so many times all the problems kinda just blur together.
msheller
where would you buy a tranny with a warranty from? for a modded sy(pte52, 2800stall+++)?
Matt
Captain Morgan
Moderated User
Matt
where do you live? are there any performance shops in your area you trust? odds are youre not gonna be able to get anything with a warrenty so forget that idea.
jwaller
Evil Genius/SyTy Guru
Matt
a warrenty comes with all my trannies. check my section for prices and details.
Ian Turgeon
Cascading Inspiration
sounds like mine, broke sprag, sun shell, reverse drum and the input shaft I think... all on a nice 1-2 shift.
msheller
I called pro trans and I'm considering it.... Jwaller can you give me your #? ....and have you guys heard anmything about mad dog trannies(the godfather, the punisher) they apparently specialize in 700r4's...heard of em? I heard jwaller is the best
Matt
Turbo6
10.20@131.8
But Morgan can break anything! :)
SeattleSy#1255
Category 5 Conservative
16Sy16 said:
HHP :tup:
thought that was our dirty little secret ;)
I vote output shaft...did exact same thing....no reverse, had to manual shift, over redline if I wanted to.
AUSyTyIN
Unbusted $#it box
I'm sure 95% of the people on here have no idea what we are talking about anyways :D
I have seen their cheezy ebay ads, I would not risk it...
TYTILIDIE
METH HEAD
I would immagine that if your output shaft broke you wouldnt go anywhere in any way shape or form. Unless you stripped some teeth on it. Checked your fluid? It tells a story.
Crimson93Ty
PITA new guy
Check fluid, inspect pan. Look for metal fragments. It's very possible that you've completely filled the valvebody up with gunk. If the valves can't move, it will act very odd. If the governor or TV is crudded, it will result in very low or high shift points(in and of itself). Broken OUTPUT shafts result in kaboom, no move. The output shaft is the last piece the force gets transferred to before going to the transfer case. Impossible to move the truck if that piece is broken. At best, you may have low only if you break it high enough on the shaft. If you have to manually shift, you probably broke the nylon gear on the governor. I've seen that happen when guys change weights on the governor and then smack the gov cover right in the middle with the hammer to reseat it. The nylon won't take that. :2cents:
msheller
Do you think its worth a flush and fill b4 the tranny rebuild appt...just in case its ridiculously gunked up???
Matt
Crimson93Ty
PITA new guy
Flush and fill won't touch it. If that is what is causing it, the valvebody will have to be pulled and all the valves and springs pulled and the whole assembly flushed out. Then you'll fill it back up with crud. It's time to rebuild/replace it.
