Re: help, no reverse and...
Check fluid, inspect pan. Look for metal fragments. It's very possible that you've completely filled the valvebody up with gunk. If the valves can't move, it will act very odd. If the governor or TV is crudded, it will result in very low or high shift points(in and of itself). Broken OUTPUT shafts result in kaboom, no move. The output shaft is the last piece the force gets transferred to before going to the transfer case. Impossible to move the truck if that piece is broken. At best, you may have low only if you break it high enough on the shaft. If you have to manually shift, you probably broke the nylon gear on the governor. I've seen that happen when guys change weights on the governor and then smack the gov cover right in the middle with the hammer to reseat it. The nylon won't take that. :2cents:
