Re: Mark Williams 32 Spline input shaft group purchase Try # 2
So just since I like to double and triple check everything, and also because I'm rather caffeine deficient today, I want to clarify what I've looked into just now. I keep seeing your posts so I'm assuming you know your shit.
I've been in the SyTy game for 14 years, but I will never claim I am an expert. There is always someone who knows more, goes faster, and so on. I will do my best to clarify everything.
I'm gonna start from the begging. The 700r4 is not the best trans for our trucks and making power. The 4l80e is much better, but does not mate with the 4472 t-case because the tail housing bolt pattern is different and the input/output shafts are different. So we came up with a new 32 spline input shaft for the t-case and an adapter plate to mount up the trans tail housing with. Due to the addition of the adapter plate, the input shaft needed to be longer than stock. Since then we now have these billet tail housings that eliminate the stock tail housing + adapter. However, since all those longer than stock input shafts are on the market, the billet tail housing was made at the same overall length of the stock housing + adapter plate in an effort to not obsolete the 32 spline t-case input shafts. There is currently no 4l80e stock length tail housing designed to bolt to the 4472 t-case while using a stock length 32 spline input shaft. And that's because as I mentioned earlier, we already have the lengthened shafts that were designed to be used with the adapter.
Is that what has happened over the last few years?
The 700R4 is a decent trans, but when coupled with AWD, it is the weakest link in the drivetrain. The first 4L80E installs used the plate style adapter and a resplined 4L80E output shaft (reduced from the larger 32 spine to a smaller 27 spline to work with the stock transfercase)
Eventually, JSM stepped up and designed a 32 spline input shaft for the transfercase so the use of the weak, resplined transmission output shaft was eliminated.
Following that was the billet transfercase adapter which eliminated the quirky and difficult to use plate design adapter.
I do recall reading about different output shaft lengths and designs, but I believe the OE 4x4 output shaft is what everyone uses.
I've also seen a few people question if the setup would work with so and so's input shaft, with the general consensus being yes. Are all the 4l80e - 4472 input shafts pretty much the same in regards to their overall dimensions?
talking in terms of mating up the trans and transfercase, this T-case input shaft is of exact dimension of the OE piece it replaces, so there should be zero issues with it. According to posts on the forum, either adapter will work as well, but the billet one is clearly a better design, easier to install, fewer spots for leaks to occur, etc.
Edit: My truck has been on the far back burner for many many years. I pop into the community every now and then to see whats new and there is always something different. So I get an idea in my head about how I'm going to do this, but then a year or so later there's a better way to do it. Unfortunately this leads to confusion on my end as I'm never 100% focused on it. It looks like I'm actually going to dig into the truck in a few weeks so I just want to have everything in order. Thanks for you help and patience!
I hear you, my original Ty hasnt been on the road in 8 years, Ive just been collecting parts for it and working on other ones in the meantime.
The only thing I failed to mention before is that you will also need different driveshafts due to the 4L80E's added length. I believe its about 3" difference, so you will need a shorter rear driveshaft and a longer front propshaft.
As far as running the trans, there are many different options for that, stand alone trans controllers, using a GM TCM, or going with a stand alone engine setup that will also control the transmission.
