3 BAR MAP Operation Question
sly dvl
Ya, it's got a Turbo
Ok, so after some searching and taking some readings I've concluded that I have a 3 BAR MAP on my Sy. I was concerned because scan-tool readings were only showing a max. pressure of about 8-9 PSI when my boost gauge was showing 14 PSI. However, that concern is now resolved now that I know I have a 3 BAR.
My question is though, on the top of ANY MAP Sensor there are a few pinholes that expose the top of the sensor to the atmosphere, since it's a comparative sensor. While the vehicle is running, if I apply a vacuum to these pinholes, should I not expect to see a change in the MAP readings? I think I should, since removing the atmospheric pressure from the top of the sensor would change its reference point, and change it readings.
I'm not really looking to solve a problem, I just stumbled across this thought while doing some tuning/testing.
Norm
Re: 3 BAR MAP Operation Question
I was wondering about how to bench test a map sensor. I have a couple of them sitting here and was wondering if they are good or not. Would a hand held vacumn pump and a ohm meter work for doing the testing?
sly dvl
The ohmmeter won't work, since they need to be powered (usually with 5 volts) to make the strain gauge inside respond.
It's pretty hard to test them accurately with a meter. You could test a 1 BAR MAP. But a 2+ BAR MAP needs to have pressure applied to it to verify proper operation.
turbodig
You're incorrectly assuming that it's a comparative sensor, which it isn't.
MAP = Manifold *Absolute* Pressure , which means that it's referenced to 0 KPA absolute.
sly dvl
Hmmm... That's a good point that I hadn't considered. I was incorrectly assuming that it was comparing manifold pressure to atmospheric pressure, even though I know it's an absolute pressure sensor. Duh!
This explains much, and answers my question. :tup:
