3-Bar MAP Problem
Flyn Sy
Damn Qwik Old Guy
I've got a '93 Ty that I can't get a 3-BAR to run in, no way, no how. It has minimal mods, e.g Manual Boost Controller and JET stage 2 chip, and that's it.
Here are the symptoms that I'm experiencing with the 3-BAR installed:
1. Idles like crap when it's cold (RPM all over the map)
2. Stalls when you put it in gear
3. Idles ok when warm, although RPM is a little low (about 600)
4. When driving above 50 MPH, throws code 44 (lean exhaust), and then shuts down momentarily.
Actions I've taken to get this booger to work:
Took the 3-BAR out of my Sy and put it in the Ty.....no luck. I put the 3-BAR out of the Ty and put it into the Sy....works fine. Took the JET chip out of the Ty and ran the 3-BAR with the stock setup.....still runs like crap. Put a 2-BAR into the Ty and ran it with both the stock chip, and then the JET chip installed.......the world was a happy place.
Don't know where to go from here. Any help would be appreciated.
Static
Re: 3-Bar MAP Problem
Is the Jet chip for a 3 bar map? Sounds like you have a 2 bar program. You need to have a 3 bar program to run a 3 bar map.
Flyn Sy
Damn Qwik Old Guy
Boy, that's a good question. I can't find any info about that on-line. I'll have to call customer support on Monday.
Beavis
Still plays with trucks
Most aftermarket mass produced chips where 2bar. thats why it runs fine with it. Does your sy have a 3bar chip? Bet it does and thats why its fine. Like said above, chip needs to match map sensor......:2cents:
Flyn Sy
Damn Qwik Old Guy
Yeah, the Sy has a Phil Long chip. I guess I've just made an ASSumption :oops: that the JET stage 2 was a 3-BAR. Guess I'll find out when I call them.
sytyguy
Moderated User
Jet does not make a 3bar chip. Get a 3bar chip or get that 2bar MAP back in until you do.
