Aldl cable info needed
I need a aldl cable but not sure what one to get. My new laptop has a 15 pin serial port (female) and 3 usb ports. Do I need to get the cable with the usb connector or what. I do have a cable that I purchased from a member a couple years ago, but have never used it. It is the type that taps into the two wires behind the aldl connector and has a 9 pin female connector. I went to radio shack but they do not have a gender adapter that goes from 9 to 15 pins. Is there a way to make this one work or do I need to buy a new cable of some type?
syclone rider
Re: Aldl cable info needed
Go to moates.net i love mine never any problems and if you ever did im sure craig would get you a new one quick.
Poconojoe
There are no 15 pin serial ports, they're either 25 or 9 pin, most 15 pin ports are video ports
13Pelle
I would recommend Moates also....trying to get you the specific link for it but their page is not loading for me.
Poconojoe
Hammer head I PM'ed you my cell number, call me
If I don't answer I'll call you back shortly
I should have what you need to use and i'm less then an hour away
