Re: Another datamaster check please
How do you launch (what method)? At what psi?
Looks like you left with about 8-9 psi on the launch in this log. If you did, you may have introduced some wheelspin that hurt you as the 0-60 time (using the log) are pretty poor (6.8 sec or thereabouts). Make sure you're getting as good of a launch as possible (very important to take advantage of our 0-60 prowess, cause after, that it's less than impressive (in stock trim). Some trucks launch better (60' wise) by leaving at lower boost. Food for thought.
Couple of things that are clearer with this log.
- Definitely ice the intake/IC on race night. The cooler IATs will help give you some extra timing from the chip and make more power by cooling the charge.
- You have a boost control issue. Sloppy WG rod, leaking vac line, erratic solenoid, something.... You saw as low as 10.3 psi and as high as 15.4 psi on that run in a 2 second span. Get that fixed and get some steady boost control. Remember that if your exhaust is TOO free flowing, it can hurt you on boost control.
- How does the 2-3 shift feel at WOT? Randy may be on to something as there is a lull between frames 129 and 156. Notice how it takes nearly 4 seconds to get from 3300 rpm to 3600 rpm. Seems very lethargic. However, that does coincide with a tremendous drop in boost (and subsequently, Inj DC), so you may have a side effect there of an underlying issue (reduced raw power output from less than optimal boost control).
