Bowtie block price???
autoaddictions
I might have a option to buy a bare bowtie block brand new in the crate for 2500.00 its bin in storage for 5 years. Is this a fair deal. What you guys think.
SY-1193
Re: Bowtie block price???
GM Part #????
(located on the back side of casting by #6 cyl.)
it may also have a number ground into the front slightly left side above the timing cover look there also. GM casted later versions from oldter castings so the number on the back is the original casting but they did updates to the block like better main caps etc. and there will be a number in a ground off square block stamped # into the block on the front.
Is it wet sump? - You kinda need that or the machining cost to convert it is costly.
Price is good if it is a #10134388,#10185051, #22534333 all cast, wet sump.
autoaddictions
SY-1193 said:
GM Part #????
I know its a wet sump!! Not sure on the #s. Ill have to check that and get back to you.
Foot Performance
I think your crazy brand new in box 2500 no deal
Just give me the guys number and location and I will straiten him out :rotf:
Windedv6
Ty n 10s
10134388 Cylinder Case, V6-90 Degree
It features siamesed cylinder bores, priority main oiling. This was probably the most popular bowtie block bought in the 1990s. It came in either 2 or 4 bolt main cap setups.
10185051 Cylinder Case, (V6-90 Degree CNC Machined)
This block was revised in year 2000. It is fully "CNC machined" from the 10134388 casting. It features siamesed cylinder bores, priority main oiling, 8620 steel main caps, the three center mains are splayed 20 degrees on the outer bolts. It featurs 2" OD cam bearing at all four locations. Deck height is 9.025" and comes finished bored at 3.980". Maximum recommended bore is 4.150". The block now features wet sump oiling.
25534333 Cylinder Case (V6 90 Degree CNC Machined)
This "CNC Machined" V6 90 degree iron block was designed for sportsman racing. Same as block 1018551 except it has nodular iron main bearing caps with grade eight bolts.
Any of the above are what you want. 5051 and the 4333 were cut via CNC machines and may not be as acurately cut as the 4388 and older ones that were done via workers that had control over all the different aspects of machining them. The worker machined one normally could be bored out to 4.180. On the CNC blocks you want to have them sonic checked before you take them over 4.150. Depends on how square the block was setup with the CNC machine.
The CNC blocks came were made starting around year 2000 and had heavier front webbing allowing a 4 bolt front main cap to be used. The 5051 had billet caps and the 4333 had heavy duty iron nodular caps with grade 8 bolts.
My AWD bowtie motor is a 4333 block and has the nodular caps. I have used 30+ pounds of boost through this build. Currently I have it apart as I cracked a SRP piston ring land. I will be changing out the modular caps with billet caps as a precaution. The caps were fine and I would not be afraid to use them for the 600-700 hp range.
There are some other bowtie blocks out there also. I just picked up an untouched, never built Bowtie "NASCAR" Block. It still as the orginal 3.98 factory bore. This block has several extras such as holes cut and threaded for AN fittings through the lifter valley and transmission tunnel (for dry sump). It also has some extra threaded holes for oil gallery access holes. A big difference is that it comes with bronze sleeved .975 dia lifter bores verses the standard Chevy .945 dia.
Which ever one that you can get for $2,500, get it. Especially a new one...before someone cut all over it and screwed it up like many of circle track guys did with putting in oversized cam bearings, punched them 4.155 or bigger and decked them under 9.0.
Great Find!!
John
NOJIMMY
John, while were on the subject of V6 bowtie blocks, is there conflicting info about the nickel and tin content on some of the bowtie blocks?
True or False:
Tin and nickel are two metals that are commonly alloyed with cast iron to improve durability, hardness and heat dissipation. Some production engine blocks have the numbers "010", "020" or both cast into their front face, just above the main bearing bore. (The timing cover must be removed for these numbers to be visible.) If both numbers are present, one about the other, some say it indicates that the block alloy contains 10% tin and 20% nickel. A single number, either a "010" or "020" represents the amount of nickel and indicates negligible amounts of tin. No numbers, other than the casting numbers that are typically found beneath the timing cover, translates to only minor amounts of tin and nickel being present in the block alloy. (Note: Mortec says "1% and 2%" however)
True or False:
A high nickel block is desirable because the tin helps the melting metal flow in the casting to forge a better, tougher block (with the nickel making it harder vs stronger).
True or False
On the 010-020 blocks their suppose have better main webbing compared to the 010 blocks. And on some of the 010-020 blocks look for 2482 on the center caps as those are the GM performance caps.
Lastly (as an important distinction) Nickel may make it harder, but not necessarily stronger. Its much like the debate between hypereutictic and forged pistons. If I'm building a high-rpm screamer, some will chose a softer block because it can absorb more impact than a harder/more brittle block. Completing the analogy by comparing this to pistons, forged pistons are stronger, but softer. They will deform and absorb more shock before failure. Cast or hyp pistons actually have a higher yield strength than forged, but when they go, they GO... like shatter.
Its kinda like glass. Really hard, but if you put just a little deformation pressure on it you can break it very easily. I've seen improperly treated cryo'd/nitrated cranks fail
because of harmonics and the brittleness of badly treated casted cranks.
thanks
-Larry
James Thomas
"NO CLASS"
True or False:
True or False:
True or False
thanks
-Larry
Wow Larry, mind telling us how / where we can find this type of info? Inquiring minds need to know! Great post and good info man :tup:
_________
James
denny
Its call google
http://www.nastyz28.com/faq/engine.htm
Q: Which engines were available for the Camaro?
A: Part of the success of the Camaro was the wide variety of engine options that were available. Here's a summary of the available factory domestic engines (other engines were used in export models and some dealer-modified Camaros (LS6)):
Note: The yearly Camaro information has specific power team information available.
L22 250ci/100HP L6 1BC - Base Engine, 1970 - 1979
LD5 231ci/110HP V6 2BC - 1980 & 1981, California Only, Buick.
LC3 229ci/115HP V6 2BC - 1980 & 1981
L14 307ci/115HP V8 2BC - Base V8, 1970 - 1973
L39 267ci/120HP V8 2BC - 1980 & 1981
LG3 305ci/140HP V8 2BC - 1976 - 1979
L65 350ci/145HP V8 2BC - 1970 - 1975
LG4 305ci/155HP V8 2BC - 1980 & 1981
LM1 350ci/160HP V8 4BC - 1974 - 1981
L48 350ci/200HP V8 4BC - Horsepower varied, considered performance engine.
LT1 350ci/330HP V8 4BC - Z-28 only 1970 - 1972
LS3 396ci/260HP V8 4BC - SS only, Q-Jet, 1971 & 1972
L34 396ci/350HP V8 4BC - SS only, Q-Jet, 1970 only.
L78 396ci/375HP V8 4BC - SS only, Holley, 1970 only.
Q: What is a Bowtie, or heavy duty (nickle) block and do I have one?
A: Tin and nickel are two metals that are commonly alloyed with cast iron to improve durability, hardness and heat dissipation. Some production engine blocks have the numbers "010", "020" or both cast into their front face, just above the main bearing bore. (The timing cover must be removed for these numbers to be visible.) If both numbers are present, one about the other, it indicates that the block alloy contains 10% tin and 20% nickel. A single number, either a "010" or "020" represents the amount of nickel and indicates negligible amounts of tin. No numbers, other than the casting numbers that are typically found beneath the timing cover, translates to only minor amounts of tin and nickel being present in the block alloy.
However, cylinder wall thickness is the overridering consideration - and a block with no tin or nickel and thick cylinder walls is generally preferable to a high nickel block with thin walls.
Q: Why were the horsepower ratings on engines often under-rated?
A: There's 2 reasons for this:
Reason 1: Insurance purposes. Insurance bean counters look at tables and statistics to determine insurance rates for various cars. One of the factors in determining how to rate a car is "Factory advertised horsepower". The factory said the car makes 290 horsepower. In reality it makes closer to 350. Oops.
Reason 2: Classification for Racing. In some forms of racing (Drag racing) cars are classified according to "Factory horsepower". Again, if the car is rated at 290 horsepower (but really has 370 horsepower) and it's going against a car that REALLY DOES have 290 horsepower. Oops.
Q: Do I have "Dual Exhaust" or do I have dual tail pipes?
A: There were several different exhaust systems offered on the Camaro. Performance cars generally have dual exhaust, which helps eliminate exhaust system back pressure.
The catalytic converter made it's debut in 1975. No Camaro had dual catalytic converts (due to cost). Since only a single cat was used, each side of the exhaust dumped into a "Y" pipe and entered the cat. This right here turns the exhaust into a single system. Old dual exhaust had separate systems for each side of the engine. This would then go into one transverse mounted dual chamber muffler and exit out the back with dual tail pipes.
Generally, all 6 cylinder Camaros had a single exhaust, single tail pipe. V8 cars had a single exhaust, to a single transverse muffler, with two tail pipes. The (1977+) Z28 technically had a single exhaust, with dual resonators.
It's not uncommon to see dual mufflers under a car. These are aftermarket dual exhaust systems.
Q: Is the 400 engine a small block or big block?
A: Ah, here's a source of confusion. Chevrolet made a 400 cubic inch Small Block Chevy engine. It was considered for use in the 1972 Z28, but this was never done. The 400 was commonly used in full size cars, station wagons, Chevelles and trucks. Chevrolet also made a 396 Big Block Chevy engine. From 1970 to 1972 this engine was installed in some Super Sport Camaros. However in 1970 this engine was overbored .032" so it was technically a 402 cubic inch engine. It was badged as a 396 if installed in a Camaro. At the time, GM/Chevrolet had a policy or limit of "400" cubic inch or greater engines being installed only in mid or full size cars - not the Camaro. This is why the LS6 idea was deep-sixed as well.
So there it is:
Chevy DID make a 400 ci small block, but it wasn't used in the Camaro.
Chevy DID install the 396 (actually 402) into the Camaro from 1970 - 72. This is a 396, or technically a 402 - but it was never called a "400". To say 400 IMPLIES the small block engine.
NOJIMMY
_________
James
...Thanks James. As it turns out Ive been obsessed with building a one of a kind bowtie. It involved
-antifriction lubricants, thermal dispersants, oil shedders, corrosion and chemical resistant coatings,
-dry film and solid film lubricants, molybdenum disulifide and tungsten disulfide coatings
-teflon and fluoropolymers, thermal barrier coatings and such.
...with that I'll return to the sidelines :)
-Larry
ghettosled
SYTY SUPERSTORE
Frank, if it is the 051 block with 4 bolt mains, i would say it is a fair deal. I sold the last (10) 051 blocks GM had in stock about 2 years ago for $2500ea. and as soon as they were gone i had people offering me $3000. There's better deals out there now and then, but how much is your time worth spending hours looking to save a few hundred.. I'd say grab it while you can.
