Buster said:
The romulator will teach you. Seriously, a few day with the romulator and you'll know how to tune, a few years with a chip burner and you'll know how to tune.
This is probably one of the single most dangerous ideas I've seen on
this board.
The RTEditor/Romulator setup is very easy to use, and learn.... which
makes it extremely dangerous in the hands of a novice tuner.
The wrong bump of a mouse can blow a motor up.
Taking the time to roll into tuning slowly, changing values by small
amounts, and knowing what it is that you're changing takes time to learn.
While it's a relatively simple matter to tune the VE tables to get a flat
AFR, it takes some time to understand how the tables interact with each
other, and to understand the true relationship between timing, boost,
and AFR. It's taken me years to figure certain things out, and there are
still things that I don't understand well enough to predict what changing
a particular value will do.
You can get a long way on "By-guess-and-by-golly", but it will cost you
some broken parts somewhere along the way.
This is not unique to Romulator. Any interface that allows you to change
engine parameters "on-the-fly" depends on the operator to impart good
judgement into the values that you put into the tables. FAST, Motec, AEM-
this applies to all.
I don't mean this to discourage people from getting into tuning; just take
it slow, at a pace where you can understand things. And write things down,
so you know what you did, and how much it affected things.
Back to the original post, though-
At a minimum, you need a scan tool that can log files. Your most econ-
omical way of doing this is building your own cable (If you spend more
than $20 building it, you spent too much), and using one of the free
scan tool products. Freescan -
http://www.andywhittaker.com/ecu/ecu_software.htm
DataMaster is somewhat the SyTy standard, if you have that already
you're well on your way. You can use it x times for free, so at least
you'll have that many diag passes.
I can tune a chip based on Datamaster/Diacom data only. I don't prefer
that, since you're not getting all the good Data the WB provides, but it
can be done. I'm working on getting a few WBs together for the people
I tune for, on a deposit basis. Not there yet, though.
The big thing, though, is fix the things that are wrong. A healthy Sy with
a stock 2 Bar chip should run at least 13.7 (Alt. corrected). Slower than
that, and something's wrong. This may involve removing mods to get it
back to stock, just for diagnostic purposes.
I ran a 12.6@108 years ago, on a stock turbo with race gas and a 2 Bar
chip with 20-21 degrees of timing.
No chip in the world, however, will fix problems. It will likely only make
things worse, and may result in broken parts. Gotta fix the issues before
you can make power.
later,
Dig
'91 Sy - 11.94@114
Still Original heads, short block, and cam.
