Code $59 vs ......
jklein68
When does it make sense to consider an aftermarket computer setup like BS3 vs. running a Code $59 setup. I am in the process of acquiring parts for my engine build and am debating the options.
I plan on upgrading to a 4L80e which will require a Transmission Control Unit. TCI retails at around $900 with the wiring harness. The Code $59 stuff is about $330 on moates plus a WB02 for $200. On the other side a BS3 goes for $2,750 on sytyperf.com and will run the engine and the trans.
Will the BS3 or similar be $1,500 - "Better"?, "Easier"?, Both? vs. a Code $59 and TCI Setup?
I am trying to build a solid 500 - 600HP truck that's drivable.
Thanks!
SchnellGhostTy
Re: Code $59 vs ......
I'm finishing up a similar project with the same goal in mind. I am running the code59 setup more or less because it was in the truck prior to my build and I ran out of money a few grand ago. I'll let you know how it goes...
turbodig
This is more of a question of what your intent is, and budget.
Given that your plans are to use a 4l80e, you'll find it much simpler to implement/wire if you use an aftermarket system.
I would suggest you shop around, and don't limit yourself to the BS3.
Also, when gathering information on systems and comparison shopping, make sure you know what you're getting - Is wide band included? Is the harness/adapter included for both the trans and and engine? Is a base startup tune included? Are the knock retard subsystems included, and what other parts need to be purchased?
If who you're talking to can't answer these questions, call a different vendor.
The major advantage of an aftermarket system - Individual cylinder fuel/timing control.
The major advantage to code59 - already uses engine harness, and has extensive support.
What you're describing has been done with code59, so it's not outside the area of possibilities. It will just require a bit more harness work with regard to the trans control PCM.
jklein68
Thanks turbodig, that's great feedback. Sounds like I just need to call some vendors and do more research. The reason I brought up the BS3 is because RPM sells it, I prefer to support them as much as I can.
I'm willing to put in more work upfront if it makes the vehicle more enjoyable in the long run.
Thanks Again!
