sytyguy
Moderated User
I know that some of you have shown interest in doing this and since I did it on my Typhoon build I just finished, I figured I'd share some pics:
Items needed:
- Bypass Valve
- Threaded Adapter
- Short Oil Filter
My machinist had the adapter I needed, but you can easily pull one from a non-remote oil filter 4.3L block (3/8" hex). Don't try to pull it out of the remote adapter as you'll either strip the internal hex or destroy the adapter. The bypass valve was already in my block, but if your's isn't, check with a local machine shop (drive it in with a socket very carefully - they're fragile). The filter is a short GM filter (like you find on a 2.2L S10, Cavalier, etc...)....WIX PN is 51040.
Unrelated: And for those of you who've figured it out, please leave the cat in the bag. I'll announce it soon enough. If you don't understand this, then ignore it.
Items needed:
- Bypass Valve
- Threaded Adapter
- Short Oil Filter
