syclone rider
Subscribed!
Sent from my SACK!
Sent from my SACK!
is this able to be done while the engine is in the truck ?? my remote lines are leaking a lil bit i want to do this but do not know if i can with the engine in the truck ??
Yes, the only PIA is getting the old lines out in one piece.
I gave up on the last two and took a sawzall to them![]()
So... is there a bypass on the block? Shorter filter?
-P
That's cleaner than I did both of mine and they never had an issue, run it!
OK, just screwed the adapter in the block and will be testing for leaks tomorrow. Last few questions, which were prompted by this post about capacity, and this post about filling the holes in the radiator.
1) Capacity is reduced 1/2 quart, so start with 4 quarts and see how it goes. It would be nice not to have to 1/2 quart sitting on the shelf between changes.
2) Is it necessary to plug the holes in the radiator where the lines attached? There shouldn't be any coolant coming out, I'm assuming just old oil.
Did you put a little blue thread loc on the end so the fitting does not come out every oil change? If you didnt you might wana do that....hint....hint. As for the holes in the rad, who cares just leave emm open, it wont due the truck any harm.
