Damn A/C !!
SBNova
My A/C went out yesterday. When you turn it on, the belt just squeels loudly. I guess the compressor is shot- it doesnt turn at all when the engines running (and the belt is squeeling away).
Anyone got a good used compressor for sale cheap?
I see them on Ebay for $80 plus shipping rebuilt, and my local AdvanceAutoParts wants like $140.
TYHOGG
Re: Damn A/C !!
I was told by several a/c tech to never use a reman. unit. I bought one from Carquest and it seized up when they tried to charge it. Went with the new Delco unit and haven;t had any problems.
ty1435_4.3
Shes almost ready
Re: Damn A/C !!
Go with a NEW one. I am a parts guy and everytime I sell a REMAN, it always comes back at least once. hth
turbodig
Re: Damn A/C !!
Junkyard. Compressors like that are all over the place. Make sure you grab one that hasn't been exposed to moisture internally.
There's a filter in one of the high-pressure tubes (expansion tube) that will be full of crud, you'll need to replace it.
Dang freon is probably gonna be more expensive than the compressor...
Foot Performance
Re: Damn A/C !!
X2 i have replaced aton of these short style compressors
If you go cheap you will be in the same situation in a year or less
I am a gm man myself but very pricey(worth it to me)
Re: Damn A/C !!
You can replace just the clutch bearing. That is even cheaper yet. It does take some "special tools" to do it, but if you have a press it can be done easily....Did it on my 95 blazer and it works good now. My bearing/belt actually siezed and the motor died, and wouldn't restart.....
jimhrabe
Re: Damn A/C !!
Ive got one from my Sy Ive got a total of 40,000 miles on (Its the original and Ive owned my Sy since it was new)and it looks and should work like new $75.00 plus shipping I can get you pics if you want let me know
SBNova
Re: Damn A/C !!
Damn my luck!!!!
So I get the compressor from gt71ss, and spend the afternoon putting it in. I left the hood and door open so long that the battery went dead. I put the charger on it for a while and it started up. I closed it up and called it a day. I didnt get the system vac'd or charged, but it was back together.
The next moring I decided to drive the Ty to work. I had my Nova blocked in the other side of the shop by my 14x7 enclosed trailer. I start the Ty and see the Check Gauges light come on. I back it out, and shut it off, figuring it may be a fluke. I close and lock up the garage. I restart the Ty and the light is still on. I back it up a few feet, and shut it back down to open the hood and takea look. I open the garage again, and get a volt meter and try to start the Ty. Now the battery is dead. So I go back and grab the battery charger and a cord. The clock is ticking, and I am becoming late for work. I try to start the Ty and it still wont do it.I realize that the battery isnt charging fast because the door is open, and the interior lights are on. So I open the window and close the door, figuring I can reach through the open window and not waste the battery. Now it starts raining. HARD. So I open the door and close the window,and cover up the charger so it wont get wet.
While I am waiting I take a look at the engine and notice that the belt is loose. I missed the idler pulley under the AC compressor. The belt wasnt totally loose, just a little and the tensioner was all the way tight trying to compensate. I figured this was good- and easy fix.
So I get a wrench and put the belt back on, quickly- its still raining hard and Im getting soaked. Im also 15 minutes late for work now.
The charger gets a good enough charge to crank the Ty. I go to take the battery charger off and notice the belt has shredded. Then I notice the best part- the "new" AC compressor I just installed- had its electrical plug ripped off of it by the shredded belt. The socket is totally broken, down behind the pulley, and a small piece of it is still attached to the trucks harness.
I guess Im back to square one......
I had to have my wife bring me to work, since my other car was blocked in, and it was raining too hard to bother moving the trailer.
SY2932
Administrator
Re: Damn A/C !!
Sounds like my kind of luck :(. I say rip that crap out and save yourself 38.4 pounds:
Hell, the compressor itself weights almost as much as the roll pan on my truck:
George Blake
DONATING MEMBER
Re: Damn A/C !!
Foot Performance said:
Not to change the topic but mine only blows out the defrost any ideas???
Vac wheel in control box or the vac line coming through the firewall back behind the ecm disconnected or damaged.
Foot Performance
Re: Damn A/C !!
I am thinking it must be the control head because i am pritty sure i have good vaccum atleast the guage is shhowing good vacuum unless there isnt enuff volume i think i will try the contolr and see what happens
thanks
