Re: Damn A/C !!
Damn my luck!!!!
So I get the compressor from gt71ss, and spend the afternoon putting it in. I left the hood and door open so long that the battery went dead. I put the charger on it for a while and it started up. I closed it up and called it a day. I didnt get the system vac'd or charged, but it was back together.
The next moring I decided to drive the Ty to work. I had my Nova blocked in the other side of the shop by my 14x7 enclosed trailer. I start the Ty and see the Check Gauges light come on. I back it out, and shut it off, figuring it may be a fluke. I close and lock up the garage. I restart the Ty and the light is still on. I back it up a few feet, and shut it back down to open the hood and takea look. I open the garage again, and get a volt meter and try to start the Ty. Now the battery is dead. So I go back and grab the battery charger and a cord. The clock is ticking, and I am becoming late for work. I try to start the Ty and it still wont do it.I realize that the battery isnt charging fast because the door is open, and the interior lights are on. So I open the window and close the door, figuring I can reach through the open window and not waste the battery. Now it starts raining. HARD. So I open the door and close the window,and cover up the charger so it wont get wet.
While I am waiting I take a look at the engine and notice that the belt is loose. I missed the idler pulley under the AC compressor. The belt wasnt totally loose, just a little and the tensioner was all the way tight trying to compensate. I figured this was good- and easy fix.
So I get a wrench and put the belt back on, quickly- its still raining hard and Im getting soaked. Im also 15 minutes late for work now.
The charger gets a good enough charge to crank the Ty. I go to take the battery charger off and notice the belt has shredded. Then I notice the best part- the "new" AC compressor I just installed- had its electrical plug ripped off of it by the shredded belt. The socket is totally broken, down behind the pulley, and a small piece of it is still attached to the trucks harness.
I guess Im back to square one......
I had to have my wife bring me to work, since my other car was blocked in, and it was raining too hard to bother moving the trailer.
