Datamaster log please veiw.
Big Mike
Re: Datamaster log please veiw.
Frank link does not seem to be working, it wants you to sign up for a Google docs account.
TYTILIDIE
METH HEAD
I see sky high intake temps, is that normal for you? Any info on what your problems are, what the truck has?
WyoSyclone
My concern wasn't the IAT's as much as it was it running lean... 13 afr's. The idle vacuum is good, so I suspected either a leaking check valve in the vacuum lines, or a bad MAP.
turbodig
I see 2 things -
Air in IC system or kinked hoses.
Really big lean-out problems. Fuel pump or regulator or fuel filter or all of the above.
*Edit* - also bad battery or Alternator or grounds or all of the above. Low ECM voltage.
