Re: front end noise
I still have a similar problem neither Dave P. or myself could figure out. When you turn it pops repeatedly until you straighten out then it fades away.
-We replaced the half-shaft w/ a known good one and that didn't solve it. It's actually louder and easier to get to pop.
-We replaced the driverside seal on the front axle at the same time and figured we'll try a half-shaft Dave had laying around.
-Dave looked at the torsion bar mounts and said they were good.
-I grabbed the wheel top/bottom and sides and tried to shake and theres no movement so the balljoints are good.
-I grabbed/shaked the steering pieces, they feel good.
The sound is the loudest when you listen to the top half of the driverside wheel-well. I'm leaning towards an axle bearing, but it's so loud and kind of sounds outside of the front axle LIKE its a CV. Then again we can't pin point the sound at all, even after a long time popping it back and forth. Ideas?
