front end noise
finallyfooned
i am not sure what side it is coming from but every time i back up and the wheel is turned to the left it makes a popping noise. i changed the idler arm thought that would help but no luck. also changed inner tie rod end. got less play in the steering wheel and thats it.
X
xanth
Guest
Re: front end noise
Continual popping noise (CV Joint) or just one time (ball joint?).
jpalmer
Re: front end noise
Make it make the noise, and have someone walk next to the truck and see what side is doing it, may be both.
Rexxenexx
Re: front end noise
I still have a similar problem neither Dave P. or myself could figure out. When you turn it pops repeatedly until you straighten out then it fades away.
-We replaced the half-shaft w/ a known good one and that didn't solve it. It's actually louder and easier to get to pop.
-We replaced the driverside seal on the front axle at the same time and figured we'll try a half-shaft Dave had laying around.
-Dave looked at the torsion bar mounts and said they were good.
-I grabbed the wheel top/bottom and sides and tried to shake and theres no movement so the balljoints are good.
-I grabbed/shaked the steering pieces, they feel good.
The sound is the loudest when you listen to the top half of the driverside wheel-well. I'm leaning towards an axle bearing, but it's so loud and kind of sounds outside of the front axle LIKE its a CV. Then again we can't pin point the sound at all, even after a long time popping it back and forth. Ideas?
Injected1
Re: front end noise
My guess would be balljoints. The best way to check balljoints is to jack the truck up with the front tires about 2" off the ground. Have someone lay on the ground with a flashlight and watch the balljoints while someone else slides a large crowbar underneath the tire and lift up repeatably.
Most of the time you can't check ball joints on these trucks just by shaking the wheels unless they are about to fall apart.
Treymen
Re: front end noise
I'm with everyone on balljoints. These trucks eat the stock ones in a very short amount of time. I went with Moog everything on my rebuild and will still have to replace them in about 30-40K miles.
Take the prop shaft out, go 2wd and see if it still does it. If not, it's ur transfer case. Just an idea.
But if you have Dave P helping you, thats probably been ruled out.
The Bronze
If you can determine if the noise is speed sensitive (speeds up or is louder with wheel speed) or load sensitive (pressure changes to wheels when turning for example) it would be easier to diagnose. A set of clip-on microphones work even better, but are $$$.
A popping that slowly fades out when straightening out sounds like cv joints to me.
Rexxenexx
Re: front end noise
If you think its suspension then the first thing we should do is go ahead and replace the front sway bar with a stock unit. This aftermarket one is too big and not doing it's job for YEARS. I was just too lazy to look for the old one and get new bushings etc etc, but now I think its a good idea and shouldn't take long. That is the only thing suspension-wise I totally question. There's even a little tire rubbing on the pass side I think I saw when I R&R'd the brakes. Lets Dooo it! Should be easy on your lift. Let me check my Dads house for the stock one, if I can't find it then maybe you have one? or someones selling one here. I'll also grab new bushings.
