Re: Help Using an O-scope (oscilloscope)
If you're looking at the rpm and the ignition voltage then as you increase RPM you're going to get a crazy effect on the screen as the rpm increases because your base timing (Timebase) will not be valid.
idle at 800 rpm = .075 seconds = 75 milliseconds so 100 ms/div should be about right... You'll only get an ignition/injector pulse every second rotation so actually it'll be twice the time so 200ms per div is the idle setting you need.
At 2400 rpm (one of your problem spots right?), your timebase should be
60/2400 = .025 so you might need to change it to 100ms/div
You need to set it for one rpm with the timebase ms/div and the v/div and keep it constant. Unless you only increase the rpm slightly then your timebase will be off as ilustrated above.
Pick an RPM where you have no problem that you can maintain and get a steady picture on the screen - this will show you the ignition signal.
The heartbeat suggests that the picture is moving along? Your timebase needs to be adjusted slightly to get the picture steady.
Then you need to set the truck to run at the RPM where you get all your problems. If it's an ignition issue then you will see that the ignition signal is messed up whereas it should be exactly the same.
What voltage are you able to measure? 12v DC/AC is way too low - ignition voltages are going to be in the KV ranges.
Have you tried measuring the ignition yet or are you just focussing on injectors? You should be able to get the square wave pretty easily with the injectors. Ground it to the head of the block and use the probe on one of the wires from the injectors. Your voltage should be set at 20v across the screen - don't know how many divisions there are.
If you don't get a square wave then that would be a surprise.
I'll have a look at the manual for that scope and try and be more helpful.
I'm also very close to finding out if I am going to be moving to Wilmington,Delaware, with work (Keep your fingers crossed for me - 19th April is the planned arrival date) which I believe is close to NJ so if I come over then I'll come up and try and help seing as I was one of those that talked you into buying an o scope! . I did a BENg in Electronics and Electrical engineering and this is getting my juices flowing
