ssullivan556
So here are my problems, stock truck with 81k miles:
1. The truck has a rough idle, only sometimes. I am guessing that this is dependent on whether it is in open or closed loop. What should I do to check the o2 sensor?
2. The truck has trouble shifting 2-3 and 3-4. You only see the 2-3 shift in the file but 3-4 feels the same. It revs to about 4000 rpm, hangs there for a few seconds like it wants to shift and then it shifts because I usually let off the throttle, out of fear of breaking something. As you can see in the DM file it is going above 15 psi and opening the wastgate and then dropping back to mid 14s and repeating. I was thinking that this would be caused by a vacuum leak. Somebody suggested that it might be the diaphram in the wastgate leaking.
3. STerm and the code 44 shows that it thinks it is running lean after I let off the throttle and was cruising. I recently replaced the plugs and checked them after 50 miles or so and they looked perfect so I don't think it is actually lean. o2 sensor again?
4. Wastgate Duty Cycle is 100% at idle. This means that is closed right? I thought it would be partially open.
5. What should I do about the random data errors? Are these errors in the ECU or just with DM or the ALDL cable?
Here is the file:
http://rapidshare.com/files/400205658/5_8_10.uni
Thanks for the help!
Here is the file:
