Its GREMLIN time!!! ARGH
Injected1
Bright Lights.....Bright Lights!!!!
We'll thanks to all that helped out and special thanks to Scott (UR50SLO). The truck wouldn't run right because the factory chip was not plugged into the Moates adapter. Something y brother or I never knew had to be done. It holds Afr now around 14.2-14.9 at idle.
Few more problems to sort out. If anyone has had these things happen or has any clue what could be the cause please let me know:
1. Idle is way to high, around 1700 rpm and the timing mark is all over the place. Sounds strong and clean but I have no idea what timing is at.
2. Check engine light flashes like crazy in synchronization with the farthest to the drivers side relay clicking. And it does it a lot.
3. Final thing is when Tuner pro is open and Aldl dash is open. The readings fluctuate between maximum, minimum, and "true" values (i.e. coolant temp 304.25, 217.53, 189.45, -28.65) And most of the time when this fluctuation occurs and the truck is running it sputters out and dies.
Our next step is to mod another ECM and see if that cures the fluctuation or any of the other issues.
ONCE AGAIN A VERY SPECIAL THANKS TO UR50SLO!!!!!!!
turbodig
Re: Its GREMLIN time!!! ARGH
Sounds a bit to me like the chip/ostrich isn't loaded correctly.
What kind of a setup do you have?
Bad ALDL data could be the wrong ADS file loaded..
Also, if you're using the moates ALDL cable, check to see that the 10k switch on the side isn't on.
Injected1
using an auto-tap setup.
The data is good for a while. Then suddenly the motor starts stumbling and kicking and the data coming out is bad almost like voltage is jumping somewhere in the ECU. The truck runs great for about 1 minute just idles HIGH
Injected1
Oh come on....You should be able to make it in 4 hrs in your truck!!! Seriously by best friend's dad lives in Brooksville. I would pay you to come help me get this thing right. Come up on Friday work Sat, Sun. Go back Monday or something like that. I have plenty of Sy and Ty parts and a little cash, not INSANELY RICH anymore
Injected1
What would be the best way to check for voltage issues/spikes?
As far as grounding I have tested every ground that comes from the ECM for contunuity and there are all good at the desired location. After that I hooked up the POWER PROBE and made sure all of those locations were in fact grounded and all were tight. So far so good there.
Tomorrow I am going to check the fuel pump and maybe move the relay on the frame to the firewall and remove the one there all together. I think the 2 relays on the same circuit could be the problem.
Also going to replace the IAC and see if that cures my high idle and timing issue
MRKING
New Parts for Old Trucks
As i mentioned in my pm , a simple log to share with everyone would show what voltages your seeing , your iac counts , your timing , and other relevant motor data . Help us help you . Majority of the time datalogging will show these hidden items that will help you avoid guessing and throwing new parts at unknown problems .
MRKING
Im curious as to how your auto tap works because pulled right from there site is :
Q. Will AutoTap work on my vehicle?
A. AutoTap works on all model year 1996 and newer cars, light trucks and SUV’s sold in the US, including all domestic, Asian and European makes. Enhanced parameters are available as an option on most Ford, GM, and Chrysler vehicles. View a list of available enhanced parameters. AutoTap does not work on boats or motorcycles.
Q. Does AutoTap work on cars older than 1996?
A. No. AutoTap works only on 1996 and newer vehicles.
Best results will be met with an ostrich emulator and Tunerpro RT .
Injected1
I am sorry my mistake, it's Autoprom.
Injected1
Can't figure out how to post the Datalog but if you can look at it for me I can E-mail it to you. Pm me with E-mail address.
Thank You
turbodig
Isolate the scan tool...
Go to ttspowersystems.com and download datamaster. It'll give you enough free datalogs to determine if your issue is tunerpro related.
MRKING
nope try again . thats the log of the bin changes youve made
