Injected1
Bright Lights.....Bright Lights!!!!
We'll thanks to all that helped out and special thanks to Scott (UR50SLO). The truck wouldn't run right because the factory chip was not plugged into the Moates adapter. Something y brother or I never knew had to be done. It holds Afr now around 14.2-14.9 at idle.
Few more problems to sort out. If anyone has had these things happen or has any clue what could be the cause please let me know:
1. Idle is way to high, around 1700 rpm and the timing mark is all over the place. Sounds strong and clean but I have no idea what timing is at.
2. Check engine light flashes like crazy in synchronization with the farthest to the drivers side relay clicking. And it does it a lot.
3. Final thing is when Tuner pro is open and Aldl dash is open. The readings fluctuate between maximum, minimum, and "true" values (i.e. coolant temp 304.25, 217.53, 189.45, -28.65) And most of the time when this fluctuation occurs and the truck is running it sputters out and dies.
Our next step is to mod another ECM and see if that cures the fluctuation or any of the other issues.
ONCE AGAIN A VERY SPECIAL THANKS TO UR50SLO!!!!!!!
