You don't need to seal it, just let it lay in there.On 2001-11-12 19:37, TookyCat wrote:
Thanks for your excellent instructions. A few questions. How important is it to create a seal inside the funnel with the vacuum hose? If I run my truck with the AFPR line open, it will virtually stall and die.
You've pulled the vac line of the afpr, your truck stalled?? hmmm don't think so.
It shouldn't stall, actually it will cause your engine to rev pretty high...try it.Wouldn't the same thing happen if I have a big hole in the middle of the funnel?
It will take just about 1/3 of a can to get it to stall, and after it stalls you can pour whatever is left in.Also you say to dump the last 1/3 of the can into the funnel so the motor stalls. What do you do with the rest once the motor has stalled?
Yes your engine will be revving so high once you stop drawing it in with the hose thing, it will take almost all the rest to stall it out. If it doesn't stall just shut it off.Do you just dump it all in regardless? Or does it suck up that last 1/3 at a very fast rate?
Just extra time to let the stuff work.Finally how come you suggest 2 hrs soak time while other places have said 15 or 30 minutes?
And what difference will/might I notice once this is all done, I mean what specifically should I look for? Thanks.
It removes carbon buildup and stuff that just causes your engine to be more prone to detonation. I would suggest you do it, change the oil and see if you notice an improvement then let us know.
Scott
