I've been searching the forums but I haven't been able to find an answer. If I replace the stock oxygen sensor with the LC-1, do I have to do something to keep the check engine light from coming on?
Also I was hoping someone could verify my wiring:
1. Red (12v Supply) goes to 12v Ignition Power.
2. Blue (Heater Ground) goes to seperate ground on the frame.
3. White (System ground) goes to seperate ground on the frame, or B9 on ECU if using DIG's patch. Edit: don't connect this to the white ground wire on existing oxygen sensor, just leave both white wires safely taped away.
4. Yellow (Analog Out 1) goes to black wire (sensor signal according to the Innovate manual) on existing oxygen sensor.
5. Brown (Analog Out 2) goes to AFR guage, or F14 on ECU if using DIG's patch, or is just ignored for later use.
6. Green (Analog Ground) goes to seperate ground on the frame or B9 on ECU if using DIG's patch.
7. Black (Calibration Wire) goes to LED / Calibration Switch.
Not sure why you would send the system ground to the existing oxygen sensor's heater ground, but I found it in this thread: http://www.syty.net/forums/showthread.php?t=45203&highlight=lc-1+install
Right now I an just trying to replace the stock oxygen sensor so I'm not planning on using DIG's patch yet. I'm thinking of seperate grounding everything.
Any help for a newbie to the tuning space would be greatly appreciated!
Paul
Paul
