FastBlackTA
Re: LS Swap Syclone Single Turbo Build
3530 w me in it before 12 bolt and 5 gal water tank....
It's 90+++ degrees out and I'm welding today. Welded spring perches on after setting pinion angle and checking 10,000 times before I welded it all up. Painted rear and let it bake in the sun. Been a long day.
Calvert racing has top notch service - they have been awesome to deal with.
Madman at insane chassis works helped me with rear afcos and the wilwood rear drag brake setup.
Having a hard time sourcing a GM short shift selector shaft for a 4l80 - if anybody has an extra I would like to buy it!
From another forum I found the sonax unit. Called the tech line to get info on it but I think the tech guy didn't understand what I was trying to do (I don't blame him - since the trucks are rare as soon as you mention Syclone people get lost. I will use the term "Sonoma" with any tech line from now on unless it's syty specific). I just went ahead and bought it on eBay after doing a little more reading. Hope it works. If anybody has a gm older selector shaft let me know I still may need it.
Got some brake line in to make up the rest of my system. Sportmachines kit is awesome, but I can only use about half of it since this truck is rather different from stock. Tom is a wealth of knowledge on this stuff and has been a great dude to bounce ideas off of as well as Renz.
After brakes and trans shift shaft deal I need to finish the intercooler water tank plumbing to the five gallon cell in the bed.
