Motor Install, how far to assemble
I am going to be shortly installing my motor. The motor is currently down to the shortblock.
How far should I assemble the motor?
Do I just leave it at a short block? (it would be easier to manuever b/c I am installing it by myself)
Install the Heads? (easier to torque on engine stand)
Install the exhaust manifolds?
Install the lower intake manifold?
MikeRenz
not stock
Re: Motor Install, how far to assemble
i assembled as much as possible. It's way easier to get to all the bolts when nothing is in the way.
Might want to leave the dizzy out so you don't risk banging it against the firewall.
sy#2921
BAMF
when I last put a motor in these trucks I had a ton of stuff on there. Complete motor minus the upper intake (makes it easier to see the back of the motor and stuff that is going on. All sensors were in, valve covers, full exhaust minus turbo. Leave the front brackets off, make sure the radiator is out of the way. Basically like renz said install everything you can and are comfortable with on the stand to make it easier on yourself when it is in
MikeRenz
not stock
dave...don't you have the entire front end off of the truck? radiator too? if so...i'd put all the brackets on. I'd get the rad out of the way if you haven't already...just to make it a little easier on the mind.
SY-1193
Don't forget the oil dipstick it is a PITA if you don't get that in before installing.
I think everyone forgets it. If you did 4 bolt main caps sometimes there is interference with the cap when you insert the tube...get it to fit while it is on the stand not in the truck.
Also be careful of the transmission tubing. We hit the line somewhere in Big Mikes engine compartment putting the engine in and when we fired it up there was pressurized trany fluid squirting on the exhaust and we made fire. It was easily fixed but it could have burned the truck to the ground if we didn't catch it quick.
Good luck with the install.
Norm
What situation are you for engine hoist? Is it a block and tackle that you have to move the truck around or do you have a engine hoist? I put mine in with nearly everything on it(including tranny), just didn't have upper intake and distributor. Had the manifolds,turbo everything was ready to go when installed.Did the starter after all the other wiring was done.
The front sheet metal & radiator is still installed.
I have an engine hoist, but its not the easiest rolling device. (Its my friends, but its one of those cheap chinese versions)
Syclone#892
I agree with DaveP put as much on as you can while its easy.
I normally have all front brackets, ps pump and all that stuff on its just so much easier.
I agree with leaving the upper intakeand dist off as it is easier to get bellhousing bolts or anything at the back of the engine plus no chance in breaking the dist.
Depending on if you are going to prime the motor I get the engine ready and marked to put the dist in so all you have to do is line it up and drop it in without worrying about being off or dealing with oil pump shaft.
Good luck your trucks been down for a while nice to see a lot of long term trucks finally coming together
hopefully my fuel pump comes back soon and hopefully it was my problem so I can finally get on the road too
turbodig
I had everything on except the turbo/DP, and the A/C compressor, which was still attached to the hoses. Including the upper intake. Dissy was out.
You can probably do it without, but I'd pull the Radiator out to keep from mashing fins .
Go to HF, and get the $30 engine load leveler. It is *soooo* worth the money. No jockeying of chains, and when it comes to moving it around so the MM bolts line up, it's a piece of cake.
Also keeps the chains away from freshly painted upper intakes.
My 30-yr old US-built hoist doesn't move around worth a crap, either. :)
