Re: Need help...
well if you have a newer laptop... your going to need to install the datamaster software on the new laptop...
www.ttspowersystems.com
you can run datamaster 20 times i think until you need a registration code... you're on your own there...
as for hookin up the cable... just plug the cable into the ALDL port under the dash and depending on what cable you have... (i have the serial cable) plug the other end into the back of the laptop...
once everything is hooked up, open datamaster. go to the file menu, and select record data. most likely you'll get a pop saying you need to select a comport... theres another menu up top i cant remember what its called but theres something like "connections" and there will be a list of comport 1, comport 2 etc... one of those will work. once the computer is reading properly you should be good to go.
if you have any probs, theres quite a few nor cal guys up there that you could get ahold of for some help... but you might have to drive awhile from arcata.
HTH!
btw hit up a mod to change your name... now that you've got a ty... unless you're still wanting a sy
