Odd timing issue
VermontTy
Support Our Troops
While trying to set the timing on my motor, I've come across an issue. The truck will not run while firing on 0deg TDC. With the tan wire unplugged, I manually bring #1 to TDC, drop the distributor in such that the rotor faces forward, the plugs on the distributor are facing backward, and the 'points' for the stator are facing the pickup. I drop the cap on, and #1 on the cap faces the direction of the rotor. I attach all the wires, 1,6,5,4,3,2, crank it over and it WILL NOT fire.
The only way to get the motor to run at all is to advance the whiz out of it by turning the distributor counter-clockwise. The closest I've made it to 0deg TDC and have the truck still run, is around 20 degrees advanced! It seems to at least fire at around 40 deg. Turning the distributor to where it should fire on #1 on time does absolutely nothing. What the heck is going on? Can a bad ignition module cause this? Any help would be GREATLY appreciated Thanks.
-adam
leroy
Re: Odd timing issue
Sounds like the outside ring on the balancer may have slipped.
Jim
VermontTy
Support Our Troops
It's an ATI Super Damper. I verified that TDC on the balancer was actually TDC on #1 by pulling the drivers rocker cover and watching the rockers, and also by looking in the spark plug hole with a flashlight while I manually turned over the motor.
leroy
My next guess is a bad ecm or wire from the ecm to the ignition module.
Jim
VermontTy
Support Our Troops
Tested the ignition module yesterday; tested it 4 times, got it good and hot and still passed.
ed hess
race or get outta the way
this might be an off the wall idea but...
an ati balancer cannot slip... fact
i assume this is a new motor.
put a degree wheel on the ati balancer. (remove anything needed to get proper clearance to do this.)
to do this with the ati balancer in the truck you will need to use a few washers to shim the wheel out to clear the ac and alt brackets
then use a piston stop to verify your pointer is turly pointing to tdc on the balancer. we want to make sure any adjustable pointer is setup exactly dead nuts.
then setup your dial indicator on no 1 intake valve.
make sure the geometry of the dial indicator is dead straight to the valve stem angle.
then degree the cam using the exact procedure that comp cams spells out on their website and report back here.
ed
Do you have the distributor on the correct TDC, (ie both valve are closed?) You may want to check the cam timimg to make sure its correct installed.
VermontTy
Support Our Troops
Correct: If the balancer slips, there are big problems. Correct: It is a new build. The local speed shop had a degree wheel, but no piston stop, so I'm waiting on it to come in from Jegs today to verify #1 TDC is correct on the balancer. I went MacGyver on an old spark plug and tried to make my own piston stop, but failed miserably.
The distributor is in correct with both valves closed. It runs, but barely. When I've seen them in 180 out before, it just backfired. I'll report back ASAP. Thanks again fellas.
-adam
ed hess
while your waiting go get the cylinder pressures on every cylinder and post them here.
ed
ed hess
and while your at it do a leak down test also. post those results here also.
ed
VermontTy
Support Our Troops
I don't have a compressor.
http://67-72chevytrucks.com/vboard/images/smilies/ghetto.gif
VermontTy
Support Our Troops
Compression test results.
6 = 140# ------------ 5 = 140#
4 = 140# ------------ 3 = 135#
2 = 140# ------------ 1 = 140#
leroy
I know you swapped the prom. Have you swapped ecm's? Check the wire between the ecm and ignition module for continuity?
Jim
VermontTy
Support Our Troops
I did not try a new ECM, but I will
There are 4 wires that go from the ECM to the ignition module
430-0.8 White / Purple (DISTRIBUTOR REF. HI)
453-0.8 Red / Black (DISTRIBUTOR REF. LOW)
424.0.8 Tan / Black (BYPASS)
423-0.8 White (EST)
I'm not sure what the functions mean in the real world, but the tan / black wire runs through something called "set timing connector". Is that the "tan wire" that is supposed to be disconnected while the timing is set to 0* TDC? I thought the tan wire was a single wire white plug on the top of the ECM, correct? I'll verify that there is continuity from the ECM to the ignition module on these 4 wires. The other 2 wires at the ignition module come from the coil.
The tan wire runs along the ECM harness going to the engine compartment and it should be down around the end of the passenger carpet (in the middle) It maybe under the carpet.
ed hess
hmm... interesting.... compression is extremely low from my past experience with a 412 cam on a new motor.
get the cam degreed and lets find out next what the cam was installed at.
ed
leroy
423-0.8 White (EST)
Sounds like you may have disconnected the wrong tan wire. The set timing connector is a good foot away from the ecm, towards the center of the dash at about the level of the top of the carpet.
If you don't disconnect the tan wire, timing will be way off.
HTH,
Jim
