VermontTy
Support Our Troops
While trying to set the timing on my motor, I've come across an issue. The truck will not run while firing on 0deg TDC. With the tan wire unplugged, I manually bring #1 to TDC, drop the distributor in such that the rotor faces forward, the plugs on the distributor are facing backward, and the 'points' for the stator are facing the pickup. I drop the cap on, and #1 on the cap faces the direction of the rotor. I attach all the wires, 1,6,5,4,3,2, crank it over and it WILL NOT fire.
The only way to get the motor to run at all is to advance the whiz out of it by turning the distributor counter-clockwise. The closest I've made it to 0deg TDC and have the truck still run, is around 20 degrees advanced! It seems to at least fire at around 40 deg. Turning the distributor to where it should fire on #1 on time does absolutely nothing. What the heck is going on? Can a bad ignition module cause this? Any help would be GREATLY appreciated Thanks.
-adam
-adam
