Odd timing issue
jwaller
Evil Genius/SyTy Guru
Re: Odd timing issue
leroy said:
Sounds like you may have disconnected the wrong tan wire. The set timing connector is a good foot away from the ecm, towards the center of the dash at about the level of the top of the carpet.
If you don't disconnect the tan wire, timing will be way off.
HTH,
Jim
I'm with him on this one you might have gotten the wrong tan wire. check that again to be sure. it's just before the wiring harness goes through the firewall and into the engine partment.
93ty475
VermontTy said:
I thought the tan wire was a single wire white plug on the top of the ECM, correct?
Good catch Dave and Jim...
Adam, find the connector they're talking about...you won't miss it....disconnect it, idle should really change.... but keep it running by throttling it if you need to... set timing to zero....then shut down the truck, tighten the distributor, reconnect the tan wire, pull the ecm fuse for a few seconds while you're at it (you don't really have to) and you should be ready to go....Man, you did alot of work!! I bet you won't forget where that tan wire is in the future... ;)
VermontTy
Support Our Troops
Yeah, my screwup. Hopefully that makes the difference. I thought it was a stand alone tan wire on the ECM (actually kind of yellow), then I found the tan/white yesterday that has the plug on it. It was too late to try and fire it again. I'll see what happens now. Thanks guys.
VermontTy
Support Our Troops
I did get it to fire on 0* TDC; it barely ran, and I had to keep giving it throttle to stay running enough to check timing, but it was fine. I reconnected the tan wire, it fired up and ran about 25* BTDC, is this right?
leroy
Yes. A really good ignition will idle at 0 degrees without throttle, but some won't.
Jim
VermontTy
Support Our Troops
Okay. It appears I'm set for now. DM is on the way so I can fine tune what I need to. Jim, Ed, Dave, Servando and John, thanks a lot for the help. I really appreciate you suggestions and time. I'm glad the problem ended up being me.
-adam
