Re: Piston squirters
TT350 said:
Has any one retro fitted there 4.3’s with piston squirters ?
I’ve been looking for an edge for my new pump gas motor.
It seems like all the factory turbo cars and trucksbuilt in the
last 10 years are so come with piston squirters to cool the
pistons. This has got to help detonation. If you think about
water carries the heat away from the combustion chamber
and cylinder walls but the piston is left to fend for it’s self.
I like a good hard core tech tread you guys give me your
two cents.
Chris
I'd rate it as an "it depends" thing.
The tractor pullers have been running 'em on turbo diesels for years... but they run much
higher manifold pressures. The old trick was to drill a hole in the main saddles and pound
a carb jet in it, grind a groove from the main bearing feed. The jet was aimed at the back
of each piston.
If you're going to run lotsa boost for long periods of time (> 2 minutes), they're a big help.
You're going to lose some power to windage if you run high revs. (6500+)
If you're going to run some spray, they'd be a good idea also.
In a lower boost app (15-20), I don't think you'd see much of a reduction in deto in terms
of running additional boost, particularly in a 1/4 mile run. Road racing or Open road stuff,
you definitely would.
Bottom line, I don't think it'll hurt ya, unless you're planning on spinning 'er to 8 grand.
About all it costs you is time and a couple of jets.
My .02
Dig
