quick boost question
turbodig
Re: quick boost question
is the max boost on the stock turbo with the atr pitbull chip still 14.7?
No. I've seen 20+ run on a pitbull.
Whether or not you have the fueling to do that, or whether it's knocking, that's an entirely different thing.
Flyin Ryan
hated cuz he drives fords
It's a two bar map chip so 14.5 is all it knows... sure you can run more but like said above make sure you have adequate fueling
syty9933
thanks guys , i will set it at 14.5 untill i get a afpr . I thought 2 bar was 14.7?
NecroWolf
lost marbles member
the pitbull chip has the fueling maps extended for more boost but it can not read the extra boost. if i remember right its just extrapolated so i would suggest watching data master very close if you turn it up
