is the max boost on the stock turbo with the atr pitbull chip still 14.7?
S syty9933 New member Apr 20, 2009 #1 is the max boost on the stock turbo with the atr pitbull chip still 14.7?
turbodig Active member Apr 20, 2009 #3 Re: quick boost question syty9933 said: is the max boost on the stock turbo with the atr pitbull chip still 14.7? Click to expand... No. I've seen 20+ run on a pitbull. Whether or not you have the fueling to do that, or whether it's knocking, that's an entirely different thing.
Flyin Ryan hated cuz he drives fords Apr 20, 2009 #4 Re: quick boost question It's a two bar map chip so 14.5 is all it knows... sure you can run more but like said above make sure you have adequate fueling
S syty9933 New member Apr 20, 2009 #5 Re: quick boost question thanks guys , i will set it at 14.5 untill i get a afpr . I thought 2 bar was 14.7?
NecroWolf lost marbles member Apr 20, 2009 #6 Re: quick boost question the pitbull chip has the fueling maps extended for more boost but it can not read the extra boost. if i remember right its just extrapolated so i would suggest watching data master very close if you turn it up
