Re: Quick ignition advance question
JayLo said:
Under full boost (15.5psi) Datamaster reads the following:
Spark Adv Base Degrees - 10.5
Spark Retard Degrees - 10.5
Spark AdvanceDegrees - 0.0
Does this mean total timing is really 0 degrees or does it mean it is 0 degrees plus the 10 degrees at the distributor?
I ran a 13.56 under these conditions. What is normal Spark advance for a Syclone in proper tune? I've heard it should be 10. Is there any truth to that?
Thanks for the help.
That's precisely what it means. If the spark tables are calling for 10 degrees of advance, and ESC is pulling 10 of it out, you have a net of 0.
This is assuming, of course, that you have your static timing (with the brown wire unplugged) set to 0 degrees. Any advance you have here should be added to the above net figure.
It's really pointless to manually advance a dissy, unless you're running in a class that only allows a stock chip, and you have good gas in the tank. The knock sensor will actually take more timing away than you would need to to get rid of the knock.
How much timing you should start with depends greatly on the type of gas you're running, and the quality of that gas. Also, it depends greatly on how much fuel you're delivering,
if you're running pump gas.
I've done cheap gas chips that run 8-10 deg, plain 92 chips that run as much as 14, 93-94 octane chips that were up to 17-18. Full race 116 chips that were in the 27-28 deg area.
Note that the above are *not* rules-of-thumb. Each truck wants what it wants, don't take somebody else's specs and expect them to be ok.
Start low... say, 8-9 degrees. If you're nervous, put a couple gallons of xylene in the tank to ward off evil spirits. Then slowly crank the timing up, watching your fueling and knock as
you do. Street gas must be much richer than race gas, typically in the low 11:1 area... additional fuel will allow you to run more timing without knock.
Realize that timing needs will change with different boost levels, and with the temp and humidity of the day. Also, altitude.
Timing will change what your wide-band reads, but it won't change AFR significantly. Ie, your AFR will read .2-.5 lambda less due to a timing change, but your fuel tables or boost didn't change. (Therefore, your Air/Fuel ratio couldn't have changed)
Daily driver chips should be pessimistic... if your truck likes 12 degrees and doesn't seem to knock, set it to 9 degrees. Your motor will live longer.
There is a point where more timing is no longer a good thing... the Max Brake Torque point. (MBT) Most of our cals are nowhere near MBT, but some of the bigger race cals can get there. Where this point is depends on your heads, manifold, quench area, piston dome, etc. etc.
Bottom line, though, is start low and stay timid on street gas.
Later,
