BMFB
Not to scale
well, ive got everything for my motor except rods. for my motor build i went pretty mild, using the stock cam, heads, and intake, as well as injectors. i went with some probe forged pistions that are around 8.7:1. crank is a scat evenfire. tuning on the truck was done using code 59 by myself, and i was running it @ 18psi with no detonation. (engine blew due to a bad oil pump) cranks 2 bolt with good arp bolts. for rods i was thinking about going stock, with arp bolts, and my builder says that should work fine. i could go with the eagle h beams, but to get them to my door would be 430 dollars. i know with those h beams the only way the bottom end would come out is...disastously, but it would be super stong. im really not thinking im going to want to mae it much faster than it already is, as it would need to prolly be 4 bolted, new heads, intake, injectors, and trans to make any significant increase, and that sounds...expencive. what do you guys think?
