Romulator help...
ashman
Sent it back to xtranstronics, they checked it out and found no problems. Reinstalled it and the truck ran great. Started the truck a couple hours later and it was running poorly, but running. The next morning..."limp home", no run above idle. Took the romulator out and read the bin. Two addressess had changed overnight. The internal battery is rated at 3VDC and I measured it at 3.4VDC, so it should be good. At this point, I believe the romulator is bad.
The stock chip will run the truck, no problem.
any ideas?
turbodig
Re: Romulator help...
any ideas?
Romulator isn't the likely problem... sounds more like bad connection on the
socket cable. If you don't have a ZIF socket in your sandwich board or socketed
MEMCAL, you'll be better off getting one.
This is a fairly common thing with the ribbon cable sockets.
Later,
Dig
ashman
Later,
Dig
The socket cable? Is this the cable that exits the romulator? If so, I performed a continuity test from the solder connections of the romulator through this cable, through the moates G1 adapter to the memcal female socket connections and all connections tested good, so I believe the connections are ok. Keep in mind that the truck ran great for ~20miles, then I parked it for ~8hours and it started running bad, 12 hours later "limp home". I never touched the romulator/ecm setup during this timeframe. When I reinstalled the stock chip, the truck immediately started and ran.
I'll be giving xtronics tech support a call tomorrow and maybe he can step me through some troubleshooting steps.
On your recommendation, I went ahead and ordered some ZIF sockets, just in case.
thanks
kue
I have constant problems w/ my romulator as well. Now I only use it while I am actually tuning. Once done, i burn a chip.
The problem I have is the unit getting hot/warm. My ECU is in the glove box. When I have the romulator in the glove box, it gets warm and stops working (truck goes into limp mode.) Depending how warm it gets, it may act up for a split second then continue to work properly, or just not work until it cools. When it gets that hot, I can use a little of the canned air duster to get some air moving around in there to help cool it off.
One thing to note is that this problem did not occur when the ECU and romulator where on the floor.
ashman
Spoke with George at Transtronics today...told him the story and he believes the romulator memory chip may be bad. He's going to replace it as it's still under warranty. I'll post if that takes care of it. Went ahead and ordered a BURN1 from Moates, also...with the ZIF's.
93ty475
Later,
Dig
To add to this, I call xtronics asking for a "longer" ribbon cable....they said no way it'll work....moates actually sells a longer one that works with the pocket romulator....xtronics said the romulator will not work correctly if the ribbon cable is shortened or lengthened....
ashman,
I went ahead and ordered the burn1 as per your recommendation....also the HDR1 memory adapter for $10.00....did you buy that as well? have you had any other romulator troubles?
thanks,
ashman
thanks,
yeah, i ordered the HDR1...makes life much easier. I spoke with George (tech guy for xtronics) at length about the issues i was having, and he finally decided that my romulator was bad. he sent me a replacement it is working fine.
