ashman
Sent it back to xtranstronics, they checked it out and found no problems. Reinstalled it and the truck ran great. Started the truck a couple hours later and it was running poorly, but running. The next morning..."limp home", no run above idle. Took the romulator out and read the bin. Two addressess had changed overnight. The internal battery is rated at 3VDC and I measured it at 3.4VDC, so it should be good. At this point, I believe the romulator is bad.
The stock chip will run the truck, no problem.
any ideas?
any ideas?
