Syclone Misfiring
re: Syclone Misfiring
I couldn't really tell if it does, but I'll have to clean them off to get a better look tomorrow. I didn't get much done today because I was busy *BUTT* I discovered something. Like you suggested, I wiggled the tan wire around under the dash. When I did, it significantly changed the way the truck was running. We may be on to something here..
I will definitely be checking that out when I remove it. The engine was replaced at about 95k miles according to the reciepts, and the truck is now at about 145K.
There is a setting in the chip/TunerPro RT that sends the idle to 1300 when the ALDL is connected. It's that or the resistor on the side of the cable you are using is switched the wrong way. What ALDL cable is it?
The ALDL cable is by Red Devil River. I will check the Settings on tunerpro tomorrow when I work on it. After I did the log, with the cable disconnected, the truck would run at a high rpm as soon as I grab the lever and put it into gear. Then after a couple min of driving, the RPMs would randomly go back to normal. I noticed it does this after I do a log session. It's wierd.
There is no way that I know of the check the injs without pulling them. I'd skip that for now. Damian answered the Vortec question. Just to be sure, you haven't said, that you set the FB with the vac line off. From what you've just said vac lines are a probable issue. there are check valves in that system to prevent boost going into a system that should only see vacuum. Are those valves there? Are they installed correctly? Sportmachines sells a nice kit to fully replace everything.
GMC Syclone Typhoon Silicone Vacuum Line Kit
Why the heck it goes to 1300 rpm when you connect the computer is weird. Also you need to check the knock sensor. The ECM needs to know that it's there and working. Get something called dialetric grease to coat the porcelain on the plugs. This will help. Get the tool I mentioned and stop pulling on the boots. IMO It's virtually impossible to not pull on the wire otherwise.
Look at your log and tell us the IAC (Idle Air Control) counts. It should be around 30. If it's different let us know.
It's also possible, but unlikely, that you have a bad coil. In my experience they usually fail completely but your symptoms indicate a weak spark. If you choose to replace it try to get the genuine GM coil. Or a name brand replacement.
Check this: When you turn the key on does the factory boost ga go to "0". 9:00 o'clock position? Or somewhere else?
Since the previous owner seems to have fooled with stuff inspect all the engine wiring for splices, broken wires, whatever. There is a water temp sender o the drivers cyl head. Is it connected?
I did remove the vacuum hose off the regulator when I adjusted it. Which by the way, I noticed the truck runs far worse when I disconnect it.
I didn't get much done today, as I was busy, but I did try what Damian said about wiggling the tan wire. When I did this, I changed the way the truck ran significantly. So we may be onto something.
I will definitely check out the vacuum lines and check valves when I work on it tomorrow and let you know. There is alot of funky splicing and wiring to be checked out. It had a clifford alarm system in it that I parcially removed and disabled.
I ordered that tool you mentioned. When I installed the plugs, I put the dielectric grease on the inside of the boot (Not on the metal). That's also what I put on the ICM. When I went to the auto parts stores, they said the only way to get the heat sink compound is to order the whole ICM. I dont know why the hell I didn't get any with min, but I was told the dielectric & heat sink are almost the same thing.
Everything else you suggested in your reply I will get to tomorrow since I won't be busy. And I'll get more pics up
Heat sink compound:
Best Heat Sink Compound Parts for Cars, Trucks & SUVs
Dialetric grease:
Permatex Dielectric tune-up grease 22058 - Read 1 Reviews on Permatex #22058
I think you need to find a different auto parts store. Dialetric grease and heat sink compound are not the same and are common over-the-counter items. Dialetric grease looks like Vaseline and heat sink compound is a white paste.
When you took the vac line off the FPR and it ran "far worse" I'm, again, suspicious. That vac line should only go 3 places. A "T" shaped piece of hose with the middle piece to the back of the intake manifold, one leg going to the FPR and the other going to the MAP sensor. And nowhere else. No check valves or anything else in the line. It should, in my experience anyway, make almost no difference in the way the motor runs. You've only generated a rather small vac leak that the IAC should handle.
There are two other vac connections. One on the bottom of the throttle body that only goes to a ck valve and then to the canister. And the "big" one off the front of the manifold that goes to the vac tank (under the bat), heater A/C system, EGR solenoid, cruise control. There are 3 ck valves. The one mentioned and one before the lines going to the vac tank, heater, and cruise. And one between that line and the cruise control. All the ck valves should only allow flow toward the intake.
IGottaSy
The ALDL cable is by Red Devil River. I will check the Settings on tunerpro tomorrow when I work on it. After I did the log, with the cable disconnected, the truck would run at a high rpm As soon as I grab the left and put it into gear, then after a couple min of driving, the RPMs would randomly go back to normal. I noticed it does this after I do a log session. It's wierd.
Did you disable the 10k resistor? That could cause high rpms as well since it kicks the ecm into diagnostic mode for some cars... towards bottom of the Q&A section...Red Devil River - Fiero Swap Harness
Damian
Do what I did to fix that, I just got some of these (Dorman Disconnect terminal 638-269 - Read Reviews on Dorman #638-269) but get the male and female of course, and just cut the original ones out and replace them with those. Worked on the Ty we had in that had a random code 42.
Well then, there is definitely something wrong here. My vac lines go from the FPR to a T that goes to the back of the manifold, then to the MAP sensor like you said. But there is also a T from the FPR that goes to the Wastegate actuator, and to the BOV.
I just read that it's supposed to go from the Wastegate actuator, to the Wastegate solenoid, which is a little back box on top of the turbo. And for some reason, mines not there, and I can't find it. Wtf ????
In the first picture is my FPR and the lines going from it to the manifold & MAP. But it also Ts from the FPR to the Wastegate actuator, as you can see in the second pic
EDIT: Looks like I'm going to have to find another way to post pictures...
Damian
Can I just wire nut them until I get the connectors?
It will work, I just wouldn't leave it like that. If you weren't on the other side of the state, I'd say bring it over. You aren't too far from my in laws though, they are just south of Fresno.
Well it would be nice to meet someone else with a SyTy. The only syclone I've ever seen in my life is mine. If only I knew of Don W when I got mine. I picked it up in Santa Rosa.
Actually I do have some of those connectors. I'll just do that now.
Well I thought I was the only one. However a few years back I was driving the Sy and a guy yelled at me "I got one of those." Maybe that's yours now???
Anyway, It's been a long time since I've see a stock turbo setup but I think there is a fitting on the turbo that goes to the WG solenoid, then from the solenoid to the WG. What I don't know is which fitting goes where on the solenoid. But since you can't find your solenoid... Is there a small fitting on the turbo? Possibly with a plug in it? Based on what you're describing the WG is seeing manifold pressure/vac and is opening prematurely. I would tell you to find that connection and put a hose from there direct to the WG actuator. This will serve to keep your boost low until you get things fixed. This is probably your "low boost" issue. But that's what you want for now.
Someone else please chime in here on the turbo plumbing.
I'd also say to make that connection on the back of the manifold go only to the FPR and MAP. Also check the other lines, that they go where they are supposed to and have check valves going the correct direction.
What the WG solenoid is is a variable valve that can open a little or a lot based on its "duty cycle" allowing more or less boost into the WG thus controlling boost by opening the WG.
IGottaSy
You basically hook your vacuum from the intake to the boost solenoid, then connect your solenoid to the waste gate. The solenoid has two nipples. One is for the hose the other should have a foam filter and no hose connected to it. There should be a Y with a restricted side. Plenty of info online..
where do all vacuum lines go?
Question on turbo vacuum lines
Ok, so I am back and i am spending the rest of today just working on my truck. I did find a fitting on the cold side of the turbo. It's got a little tube coming off of it with a screw in the end as a plug. I'm going to run the line off of that, to the Wastegate actuator and BOV, and correct the FPR vacuum lines routing. I'll also try to find any other incorrect vacuum line routing
Ok so I have made some discoveries. After I corrected the vacuum lines the truck has been running alot better. Not perfect but definitely better. I would drive it, them come to a stop. I felt no slight bump, hiccup, stutter, nothing. I go into the auto parts store to pick up some connectors for the tan wire under the dash, and when I get back in the truck and start it, it's running like trash again. Wtf. I get home, shut it off for a few min, get back in, start it, and it's running good again. So I shut it off again and restarted it, running like crap. Shut off, start, running good. So the truck changes the way it's running whenever I restart it. I've also got the code 42, and now a code 45 stored in the computer. Code 45 is O2 sensor detecting the truck running rich.
