Syclone Misfiring
IGottaSy
re: Syclone Misfiring
Ok so I have made some discoveries. After I corrected the vacuum lines the truck has been running alot better. Not perfect but definitely better. I would drive it, them come to a stop. I felt no slight bump, hiccup, stutter, nothing. I go into the auto parts store to pick up some connectors for the tan wire under the dash, and when I get back in the truck and start it, it's running like trash again. Wtf. I get home, shut it off for a few min, get back in, start it, and it's running good again. So I shut it off again and restarted it, running like crap. Shut off, start, running good. So the truck changes the way it's running whenever I restart it. I've also got the code 42, and now a code 45 stored in the computer. Code 45 is O2 sensor detecting the truck running rich.
Could be mismatched injectors and chip/tune.
Damian
Pull the distributor cap off and inspect the inside around the magnets. Mine was all rusted up inside and did the same thing. New distributor and ICM and helped a lot.
Jay92Ty
Gotta love these trucks! :tup:
:rotf: serioulsly..I hate my trucks but I love the F#%# out of them. Just like women, they drive me nuts but I love them:lol:
Following this thread, curious to see what the ruling will be. Good luck!
What Damian mentioned about the wiggle in the tan wire worked for me on a 92' S10Blazer I had. Fixed the code 42 problem. I was really hoping it would have fixed it for you.
I just now looked, and it's pretty damn rusted in there..
Soo, it was a crows foot wrench right? To remove the dizz
Unfortunately, I haven't got to experience what these trucks are really capale of. I've just been driving it with only 2wd and no more than 5 psi of boost. Can't wait to get it running right, then crank the boost to stock, and replace or rebuild the T case. Then try out my first boost launch and rocket to 60 in under 5 seconds. Wouldn't that be nice..
As for the code 42, that may have fixed it. I'm not completely sure yet. I haven't had any check engine lights on. Even before I changed the connectors.
Well a rebuilt dist sure wouldn't hurt. The way you describe your starting, good once, bad the next, it might be worth a try. Why 2 wheel drive? What's going on there?
Jay92Ty
It'll be a blast once you get it going. Not really sure how bad your misfire is but I always see post on here (and also from my own experience) that these trucks from factory never really idled right. They do have a small hick up in the idle. My buddy use to have a Sy and it drove him nuts:lol:My Sy is pretty much stock. When I put the chip, it did change a bit..but not much. Not saying there's nothing wrong with your truck, just saying that the misfire could be smaller than expected. Really hope you solve this mystery.:tup: it'll be a shame not nt be able to drive it at its full potential.
Should I just go with a new or reman dizz from my local auto parts store? That way I could get it faster.
As for the 2wd, viscous clutch is locked up. When I got the truck, it had mismatched front and rear tires, and a snapped CV axle.. Hmmmm I wonder what happened here. He at least had 2 new axles with the truck. So then it sat, and was posted on CL. I managed to trade him my 01 4x4 dodge pickup for this little rocket truck. I've always wanted one, so I got extremely lucky to get an actual running Syclone, for my 3k dollar pickup.
So anyway, I've got the propshaft out until I get it running g right, then another T case.
Here's a link to a picture of my Distributor. Let me know if it works, so I can get more pictures if it does.
http://i1064.photobucket.com/albums/u366/MPMX94/SYTY UPLOADING/20170724_193530_zpskrreyb8c.jpg
Thanks! There's definitely a problem, since there's been times when it's run far better
Quickstop [UK]
Combating adversyty.
Re: Syclone Misfiring
I love following a thread where the OP tries stuff and perseveres. You're a dying breed - keep it up and you'll be a happy man!!!
WyoSyclone
This could be a MAP sensor going bad...
Yah I won't leave this thread until she is running right and under full boost. It's great that you guys are helping me out here, but I hope it also helps other people out in the future who are having similar problems with there truck.
OK, so I have replaced the distributor with a brand new duralast gold, which cam with the ICM, cap, and rotor already installed. (This was an absolute NIGHTMARE. I seriously might have nightmares about that hold down bolt) i also set the timi g to zero (large notch on tab on drivers side WITH the tan wire unplugged)
And now the truck is running alot worse. It cuts out on power under light throttle, and I have to double foot it because it might die. I've also got a check engine light now, with just a code 42. This code 42 is definitely my problem. I shouldn't have been ignoring it. I'm wondering if it's bad wiring, because I had to Unplug and plug in the ICM, and move wires around back there. Tomorrow I'm going to diagnose the code 42, because i believe this is the problem.
OK, so I've been trying to figure out this code 42 problem. I followed the diagnosis procedure on the code 42, and it led me straight to open circuit/faulty connector/wiring. So I looked behind the dist where it connects to the ICM, and there is NO slack on that wire, it's is pulled to the side with some tension on it. So I pulled the harness up to allow some slack, and wiggled the wires around, and guess what?? The truck has no ignition now and will not start. I returned the wires to the position they were in before with the slight tension, and no start, wiggled them, unplugged them and replugged them, and no start. The auto parts stores don't seem to have the new connector/wires, so I have to order them. This really sucks because now i have no vehicle, but I do have access to others luckly. I believe this is the whole problem to the missfiring issue.
Have you tried the other notch on the balancer?
On the balancer itself? I think there is only one mark on it. I was going off the mark that was displayed by the timing light, connected to the #1 plug wire. But if you're referring to the notches on the tab, I tried all 3 before I figured out which was "zero". It ran pretty much the same between all 3 notches
