WyoSyclone
Ok, some of you guys know I've been fighting an issue with trying to get timing into my tune.
I spent all day Friday changing plugs, doing a compression check, ohming out all the wires, rerouting the sparkplug wires, and rechecking the motor for TDC.
With the motor at TDC (timing mark on balancer did line up) I put a piece of tape across the top of the intake lining up exactly with the centerline of the rotor (which should have been pointing at exactly TDC #1. I put the cap back on then turned the distributor till the #1 terminal on the cap was lined up through the centerline of the cap with that same piece of tape. Truck fired up instantly, sounded great.
I disco'd the tan timing wire and the truck immediately died, wouldn't start.
In Code59 my F1 table is commanding 24 degrees of advance at idle. So, after all of that here is my question...
If I connect the timing light, and punch in 24 degrees of advance in the light (Actron digital timing light), the timing mark on the balancer should appear to be lined up with the pointer - 0 degrees - right?? In essence, this is using the timing light to hit zero, instead of disco'ing the tan wire..... am I making sense??
I assume that if I do this, then disco the tan wire the truck should still run... not well, but run long enough to then check the timing mark with no advance programmed into the light.
Okay... blast away... I'm tired from digging holes for 12 new trees and may not be thinking straight
