Timing Question... maybe dumb :)
WyoSyclone
Ok, some of you guys know I've been fighting an issue with trying to get timing into my tune.
I spent all day Friday changing plugs, doing a compression check, ohming out all the wires, rerouting the sparkplug wires, and rechecking the motor for TDC.
With the motor at TDC (timing mark on balancer did line up) I put a piece of tape across the top of the intake lining up exactly with the centerline of the rotor (which should have been pointing at exactly TDC #1. I put the cap back on then turned the distributor till the #1 terminal on the cap was lined up through the centerline of the cap with that same piece of tape. Truck fired up instantly, sounded great.
I disco'd the tan timing wire and the truck immediately died, wouldn't start.
In Code59 my F1 table is commanding 24 degrees of advance at idle. So, after all of that here is my question...
If I connect the timing light, and punch in 24 degrees of advance in the light (Actron digital timing light), the timing mark on the balancer should appear to be lined up with the pointer - 0 degrees - right?? In essence, this is using the timing light to hit zero, instead of disco'ing the tan wire..... am I making sense??
I assume that if I do this, then disco the tan wire the truck should still run... not well, but run long enough to then check the timing mark with no advance programmed into the light.
Okay... blast away... I'm tired from digging holes for 12 new trees and may not be thinking straight :D
rockclone
Re: Timing Question... maybe dumb :)
I had a issue with one of my trucks simaler to that and i moved aqll the wires over one hole and it was fine after that.
WyoSyclone
Well, that's an interesting observation.. I'm trying to think it through on my tired brain.. hmm, spark reference angle, 360/6=60, I'm having a hard time seeing the correlation.. I'll think that one through tomorrow morn.... thanks for the input :D
gstjohn
Sycloned S-10
I was just checking timing on mine this weekend and from what i can see as long as you know that the computer is giving 24* then your timing light with the 24 degrees on it, you should see the timing mark at 0. I usually shut down the engine and then disconnect the tan wire, that way I dont run the risk of either shorting out a wire or something happening. not sure if it could happen but id rather be safe the sorry. I was disconnecting the tan wire, check timing, set to 0 and then shut down re connect tan wire and then check timing with the 24* in the light and it should be at 0. mine is but its non code 59 and i was checking it with the stock chip selected in the prompaq.
turboj91
Moving all the wires over one post works if they are in the wrong place to begin with and the dist. housing was not moved. You can use any post to set #1 as long as you install the dist. #1 firing at that post and run the proper firing order from there. If your range of adjustment for the housing (won't rotate enough to get the timing you need) you can move it one tooth. It is all about the relation of the rotor to the post on the cap. Anyway, in your case, your asking about a different subject than rotor to post relation or proper wire placement. If the ecm is putting 24 degrees advance at idle and you set the light for 24 degrees, if your initial timing is at 0, then when you unplug the tan wire, you should be at 0. If your initial is off and you have 24 on the light, the initial will not be at 0 but what ever it is. If the truck does not run with the wire disconnected, the timing very well could be ATDC. You would then need to advance it to 0 and you should be good. For some people that do not know what their mechanical advance is (for that type of distributer) you can rev it up, turn the timing light until the mark hits 0 then look at the light and see how many degrees show and that is the advance in the system. If you put 24 into your light and have the truck at idle and it is not on 0, then your initial is off. You can punch in numbers on your light until the mark lines up at 0. Anything less than 24, subtract that from number from 24 and that is how many degrees retarted you are (the engine not you) and how many degrees of advance you need to get your initial to 0. If it is more than 24, then you are advanced and need to retard by the overage to get to 0.
hth
jwaller
Evil Genius/SyTy Guru
:D
yes, dieal in 24 and you should line up with zero on the balancer. a lot of trucks esp with vortec heads won't idle with 0 timing. I do this all the time and it's quicker and easier to do it this way.
WyoSyclone
Thanks everyone :tup:
I was pretty sure that was a valid method, but just wanted to confirm... I'll double-check the timing later today.
turbodig
Delivered timing is the sum of that table, as well as a couple other tables and corrections.
You really need to calculate the total timing number, and dial that into your timing light.
Also, the timing in the RPM and MAP cells around your idle speed/map must be exactly equal, or slight RPM/MAP drift will skew the timing.
Will it run at 1000 RPM with the wire unhooked? Generally, the ones that I see that won't have too much idle fuel. Pulling the wire causes timing to retard, and leaves a lot of unburned fuel hanging around, which mixes with more incoming fuel, and eventually snowballs into the stall.
WyoSyclone
Thanks for the input Dig.. I appreciate you chiming in on it. I'll post over on '59 and I'll ask over there for the various tables that may affect that total value - or I may have found them by then. Truck idles right at 14.9 and bounces 1/10th up or down every so often.
I'll put the cells in a 4x square around the idle value in F1 to the same value.... I'll do some experimentation, see what happens, and post back.
WyoSyclone
And the 'spark advance' number shown in DM at an idle would be the total timing with the other 'tables and corrections' applied, correct??
Thx.
