Ok, got some weird results last night tuning with the methanol.
PLUG GAP .032gap on the UR6 NGK's i was getting IGN breakup under 8-10psi. I tried this with a .030gap on the UR5's with IGN breakup at 10-15psi. Well i regap'd the UR6's with a tight .028gap and it doesnt breakup running 17-18psi. Weird thing is if i take off the dump plate on the PTE downpipe it will breakup hardcore at 10-15psi. :-? Doesnt make sence
FUELING I've worked my way down to 38psi base FP and get to much light throttle knock, even turning the gain knob to 2-3o' clock. My turn on point is 4psi with the meth. It seems to like 43-44psi base FP any less or any more i pick up light throttle knock. at this FP i get good driveability and 2deg max spikes at the 2-3 shift at WOT.
Man this thing is pulling hard at 17psi. Im going to adjust the wastegate rod to run 20psi with the dump closed for now untill i figure out the open dump IGN breakup situation. Anyone know why :-?
BTW it only likes the lean settings in the Ultimate 50# chip, any richer is
to much fuel in boost with the meth. Track this weekend
