Tuning with Alky
bezerk
SyTyJedi said:
Erik said:
Wow :eek: No one here is using a 50# Ultimate with Alky/Meth injection....
I am - truck is not running. I have Razor's kit and an ultimate chip.
BTW anyone ever use the FJO wideband setup?
I was planning on it if it will work with Datamaster like the Innovate does. I like the FJO display and was planning on mounting it on top of the column for easy viewing.
please keep us posted, i like the unit ass wel,
0966Sy
Code what?
Im very close to having some feedback on the kit. Im finishing my AC delete project and have all the hardware mounted for the razor kit. Im waiting on RPM's AC delete tensioner setup and i'll be spending some time fine tuning with datamaster. I'll also be hitting the track soon with it before they close for the holiday's. BTW the truck went 7.9@85 on 15-16psi in the 1/8th with little knock. Will see how it likes 20-22psi with meth :evilbat:
Tydriver
TurboLS6 Powa'
JS Manufacturing said:
Local auto/race shop has it here. ~$2 gallon or so.
Forget being an alchoholic, go straight to meth. GRIN
Now were just hoping we don't find any crack when using it.
So much for the not finding any crack while playing with METH huh Jeff ??
Any updates on when its gonna be fixed ?
For everybody elses info, we ran up to 27psi of boost on pump, with 2 deg or knock. Beyong stock turbo efficiency though. Wasn't on purpose either.
And to Todd's question, most likely tomorrow evening if not today.
0966Sy
Code what?
"For everybody elses info, we ran up to 27psi of boost on pump, with 2 deg or knock."
You have got to be on METH to run 27psi on stock internals :eek: :D
0966Sy
Code what?
Ok, thought i would bring up a couple things concerning the Razor kit. I have asked Julio a couple questions on the phone regarding installation.
He told me to make sure the allen adjustment screw on the top of the Shurflow pump was tight (clockwise) do not overtighten, just stop as it gets hard to turn. This allows the pumps output to work at it's fullest potential when needed. Not sure how? i guess a spring that controls the rate of flow.
Also, very important. Do not use AN fittings with alcohol. They make speacial AN fittings for the use with alcohol, they are made with an anti-corrosive.
They also have speacial braided line for alcohol, not all braided line can withstand alcohol use. Im using some Goodridge that will work, also try XRP, Russel they make alcohol resistant lines.
Just thought i would throw this out there for some planning on getting a Razor/Alky setup. Julio's kit comes complete with more then enough to make the installation easy. I needed to lenghthen my feed line to the pump from the tank and almost used AN fittings at the pump untill i talked to Julio.
SpoolingTurbo6
re:
re:
The screw is for pump output pressure, if this came with wires on it from us Don't mess with it,if it came without wires on it tighten it 6&1/2 turns.
Our hoses are impregnated teflon rubber the is compatible with lots of fuels.
We use AN fittings on these kits (you cant use Anodized fittings) as long as it's brass!
note to admin We need alky sec. :rock
0966Sy
Code what?
Getting closer to tuning with the Razor kit. Im expecting my AC delete kit from RPM this week. And that is the only thing holding me up. Everything is installed and looking good. I've got my propshaft taken out from when i had planned on dynoing the Sy with 20psi with 110 octane. Then i went the Methanol route and it's been sitting sence. Once it's ready to role it will get a tollroad tune. Im dynoing it thursday the 18th with 20-22psi and hope to put down some good numbers. Following the dyno i will be hitting the track that weekend.
I'll make a post on details of the Sy's mods with the intention of giving some more proof on the Razor kit on a mildly built Sy with a stock motor.
0966Sy
Code what?
Ok, I got the truck running and spent a few nights tuning with DM. Well I have a few issues to resolve. Dyno at school ended up breaking, again :evil: Wasnt ready to Dyno anyways.
I have some RPM Tach flutter above 4k, this is probably from EMI feeding back into the IGN circuit in the fuse block. DTC Flags flash red on DM with the meth spraying. Although it doesnt store any DTC codes on DM, i did get one code shortly after testing the kit. Code 34 (Low MAP volts) I cleared it and it hasnt came back sence. This was from my Battery being undercharged and running a power invertor for the lap-top from the cig lighter. Although it is working fine after charging the battery. The connection at the MAP is solderd and heat shrinked.
When i first started testing the kit the turn on wouldnt come on untill 7psi. I lowerd the turn on point to 4psi. I worked my way down with FP from 45base (50# Ultimate V7) using T1F1 to insure accurate base FP changes. Got it down to 42 with little knock. Gain controller around 12 o'clock. took off the dump plate to test 20psi and started getting ignition break-up around 8-10psi. Wasnt getting this at 15psi with the dump closed. I had gapped my NGK ur5's at 28 to test the lower gap, im sure this is causing the break up. Plugs looked good with no signs of detonation. Im going to try a 32 gap on fresh plugs and try 20psi. Lowering base FP seems to decrease initial knock. IAT's where low 60's at 15psi in 60f outside temp. Anyways, Ran out of Meth for now. More to come.
93 TY 2185
I'm using Razors kit and also had tach flutter. I'm using stock injector not the #50’s.
I had to gap my plugs down to .028 to get rid of the ignition (tach flutter) problem.
PPI Typhoon
DIY Madman
I using Razors kit and also had tach flutter. I using stock injector not the #50’s.
I second that. I'm not using Razor's, but a home grown kit and had to regap my plugs as well. It made a HUGE difference in the amount I could spray. I couldn't even go WOT @ 15psi gapped at 35 and an M10 nozzle (not progressive), but could go to WOT @ 26psi when gapped to 28. :tup: :rock:
0966Sy
Code what?
Ok, got some weird results last night tuning with the methanol.
PLUG GAP .032gap on the UR6 NGK's i was getting IGN breakup under 8-10psi. I tried this with a .030gap on the UR5's with IGN breakup at 10-15psi. Well i regap'd the UR6's with a tight .028gap and it doesnt breakup running 17-18psi. Weird thing is if i take off the dump plate on the PTE downpipe it will breakup hardcore at 10-15psi. :-? Doesnt make sence
FUELING I've worked my way down to 38psi base FP and get to much light throttle knock, even turning the gain knob to 2-3o' clock. My turn on point is 4psi with the meth. It seems to like 43-44psi base FP any less or any more i pick up light throttle knock. at this FP i get good driveability and 2deg max spikes at the 2-3 shift at WOT.
Man this thing is pulling hard at 17psi. Im going to adjust the wastegate rod to run 20psi with the dump closed for now untill i figure out the open dump IGN breakup situation. Anyone know why :-?
BTW it only likes the lean settings in the Ultimate 50# chip, any richer is
to much fuel in boost with the meth. Track this weekend :D
SeattleSy#1255
Category 5 Conservative
two questions:
1) what do you expect for dyno numbers if you had to guess?
2) 93 ty 2185: with your stock injecters and running meth what is your injecter duty cycle running X psi?
nightdiver
What nr and how many meth injectors are you running ?
I use two 15 injectors with 0.35 B8ES ngks
May be its too rich or you got ignition problems
93 TY 2185
SeattleSy#1255 said:
two questions:
Here's a DataMaster file from one of my last race events.
I was running 38PSI of fuel pressure monitoring with with a WBo2 Sensor.
Razors Alky kit with turn on set at 4 PSI and the pump speed dial at about the 10 o’clock position.
Look at the "AFR Target" to see WBo2 data on the graph.
DataMaster File Here
SeattleSy#1255
two questions:
ya thanks for the file....injecter looks as though its close to maxed out, but that is what I was wondering.
thanks for the file again...i'll save it and look at it more later.
0966Sy
Code what?
I only have 1 nozzle that came with the kit. My Knock retard is only at partial throttle in light boost. When i go WOT it gets none up to 110mph.
I dont have a WBO2 to monitor with. I might be rich but any more less FP and it gets lots of light trottle knock. Maybe i will try to lower the gain knob to 10o' clock like wade. Mine likes the gain knob at about 11o' clock.
I cant read your DM file Wade, i dont know what program to use to read it. I dont have DM on my PC at home. Sounds like your having good results.
the .028 plug gap helped with the UR6's but the ignition still breaks up after i remove the dump. I can run 20psi with dump closed without the ignition breaking up. With no KR at WOT. Dunno :-? I've got the FP at 43-44psi base with the gain knob at 11o' clock. My Injector DC with the 50's was 60% @ 17psi
RPM TACH FLUTTER
Another question for you guy's. I've got some serious RPM tach flutter at WOT and above 4k in high boost (high pump voltage) I have my power for the kit in the IGN terminal in the fuse block, like the intructions said from razor. So it's EMI getting into the IGN circuit, could this cause false knock? So using a capacitor T'd into the power wire would resolve this issue, what size capacitor? Any other ways you guy's a wiring the power for the kit would also be helpfull.
BTW Once i get this dialed in good i will be hitting the Dyno, i would suspect 350hp@20psi and 500ft torque
SpoolingTurbo6
About tack flutter
About tack flutter
The flutter is because of the Frequency the controller puts out....And because our tachs are so sensitive to any frequency, the fix is you put an electrolytic capacitor (2200uf_@25volts) across the power wires going to the controller. It will suppress the noise down.
And if you want complete immunity,.....Put a 30 amp relay triggered by ignition, Relay get power from the screw terminal on the firewall fused 20amp, then gets hooked up to the RED on the power distribution box.
turbodig
two questions:
Looks like your minigate is having trouble keeping up on the TCC lockup.
Do you have it (the minigate) being run by the ECM solenoid, or a bleeder? The ECM could flatten that spike right out.
Also looks like you need more fuel in the Boost multiplier table above
260 KPA.... also below 2800 RPM at the 100 KPA range in the VE table.
Might also want to richen things up a bit before the Alky turn on point,
it's too lean right off launch.
Otherwise the AFR looks fairly nice... you might want to feed it a bit
more alky to get rid of that last 3-4 degrees. If that doesn't cure it,
pulling 1-2 degrees of timing in the 220 KPA + ranges in the MAP table
will likely make it go away.
later,
Dig
