Typhoon won´t start!
The_Bronze
Re: Typhoon won´t start!
Looking back again, I see where the EGR has been questioned, but don't see where you verified it was taken out of service or functioning checked.
I see recently were the timing is questioned, but I don't see real verification that it was checked.
I bring this up to make sure we are spending our efforts wisely. I have spent many hours on the phone with someone who says they check or do, but don't put out the effort, looking for something easier. :banghead:
gkrcr882
SyTyless......for now!
Without having datamaster, I would have to agree from what I've read. Things like this make me wish I had access to a 5 gas and an ignition scope. From what I gather:
ECM can be ruled out, engine is running, MIL is functioning, there is ALDL communication
Fuel system is questionable. Whether you have the correct volume and pressure is unknown at this point
Igniton system is functioning, however, the timing and firing order need to be 100% correct
Since I cant see any sensor data, I'm going to go out on a limb and guess that the IAT, CTS, MAP, TPS, CMP, and KS are functioning properly. Whether or not the O2 is functioning properly I don't know.
Some things to check:
Verify that there is no exhaust restriction. A clogged convertor **can** restrict flow to the point of not allowing the engine to rev any higher
Vacuum leaks. Either use brake parts cleaner or a propane torch, go around all the intake gasket points and vacuum lines/fittings. If things are swinging way lean, this could be a culprit. Idle should increase if the external fuel source (propane, brake cleaner, etc) gets sucked into a leak
Check the IAC and the throttle body for restrictions. I've seen it as a cause for poor idle many times
If possible, a compression check is always handy to have. Granted, you would have to have some serious leakage or very little compression at all for things to be this bad, but it can help.
Verify you have 13.5-14.5V at the battery with the engine running.
Just for the sake of checking, remove the vacuum hose from the fuel pressure regulator. If any fuel comes out, you have a ruptured diaphragm, and it can cause problems. Fuel pressure should increase with the line disconnected.
After downloading DM (thanks for the link The_Bronze!), I saw what was mentioned about the lean condition "seen" by the O2, and the low vac at idle (you are in Chrysler territory my friend!). I think a vacuum leak can be ruled out since the idle speed was almost spot on, however, why the ECM sends a lean command is interesting. Inj DC and TP % are where they're supposed to be, but the O2 doesnt follow suit. If anything, the ECM should be commanding a rich condition to compensate. I also didn't see the O2 cycle between rich/lean like it should. Does the truck have any kind of smoke or indicator of an overly rich condition? O2 can almost be ruled out though since it has no effect on closed loop operation.
The_Bronze
I would leave the PCM as a possible culprit, internal EST circuitry could be screwing up the control module firing solution, as could a defective stator or ignition module.
From the DM file, those sensors ^ appear to be okay minus the O2 sensor circuit.
Fuel pressure regulator rupture would increase the fuel by increasing pressure and delivering fuel to the intake. Always worth looking at when looking over a driveability problem, but likely won't cure anything here.
I would love to see a compression test as well. Basics usually are what cause these kind of problems or quickly rule things out.
3rd_amigo
ok i have buy a timing light
but i dont know how many rpm i must have to check the timing with the light!
can someone give me a good issue
i have searchd in the forum and in my repair manual and i dont have find anything ove rthat?!
BG Domi
gkrcr882
disconnect the ESC wire under the dashboard, start the truck and let it run at idle. Connect the inductive pickup (trigger) to #1 plug wire, and the power cables to the battery. BEING MINDFUL OF THE FAN, aim the timing light at the pointer attached to the engine, and see where the line on the balancer is in relation.
** before doing this, you may want to find the mark on the balancer (with the truck off) and mark it with white chalk so its more visible when you check it
So you don't uplug any wire under the dash, the ESC wire is below the passenger side, where the dash meets the carpet. You may even need to pull the carpet back to see it. I believe it is a Brown wire with a black connector.
3rd_amigo
hey i have check some things and all is ok but I found something that I do not normally appear!
pleas check this:
on the yellow line is my timing mark when i disconnectd the tan cable. @ idle
on the red line is my timing mark when i connect the cable.@ idle
on the green line is my timing mark when i give 2000 rpm with connected cable.
and on the red line is my timing mark when i give 2000 rpm without connected cable.
is this normally?
Phil O' Dendron
i think you should adjust timing with the wire DISCONNCTED to the RED line drawn in your picture. did that in my sy and it started at the first key turn (had to adjust because distributor was taken out during repair).
i think there is no translation problem, but:
Du solltest die Zündung so einstellen daß bei AUSGESTECKTEM braunem Kabel die Markierung mit der ROTEN Linie übereinstimmt ;)
When a language is not the one you grew up with or studied intensive, you will be able to read and understand a lot but sometimes you cannot write what you're thinking in foreign language
that an "original language speaker" gets a smile on the face.... :lol: check my posts for example :lol:
3rd_amigo
hey phil my ty started at te first key to but he runs very rough in idle - 1500 rpm and when i go in D and drive and i will do WOT then he starts to stutter!
hmmm
BG Domi
Quickstop [UK]
Combating adversyty.
hmmm
BG Domi
Yes, 0 degrees is where the yellow mark is with ESC disconnected.. Not sure what the manual says but at idle I think anything from 0-5 degrees is ok. As you increase RPM then you'll get more advance hence the green and red lines as the RPM goes up.
WOT? you're going to kill your engine at this rate. You haven't even got the timing sorted for sure. Don't do WOT until it at least idles correctly.
Did you check for air leaks around the throttle body?
have you got the PCV hoses connected? They are attached to the valve covers and go to the throttle body and also to the crossover tube.
What plugs are you running?
